Merging Z-Wave Relays
I have 2 z-wave relays that are built in the wall behind the switch. (Qubino Flush 2 Relays)
When I turn on switch 1 (manually) the light at the output of the relay switches on (default behaviour).
What I want to do is to link multiple relays, so that when I toggle one switch, both lights come on, and when I then turn of the second relay, both lights should turn off.
I tried doing this by using Z-Wave Group Associations, but this creates a loop as I need the linking to work both ways.
I have tried making a Template Light, which does link the lights, but only when operated from the HA frontend, not when I use the physical switches.
I’ve also tried making automations, 2 per relay (so 4 in total) to cover all the switching possibilities (e.g. 1 to turn on light 1 when I turn on light 2, 1 to turn off light 1 when I turn off light 2, 1 to turn on light 2 when I turn on light 1, and 1 to turn off light 2 when I turn off light 1). But I’ve never got this to work unfortunately.
Basically I need the value template of the Template light to react to both the switches. Or is there another way I could get this functionality (maybe via more elegant automation(s) or scripts?)
Here are the automations I tried: https://pastebin.com/UXELPMt9
Here is the Template Light I tried: https://pastebin.com/4V6EsK4Z (the level template is like this because I have milights behind these relays, but I don’t really need this linking to happen at that level, so just ignore that)(more info on that: Combining Z-wave Relay with Milight light )
You should be able to simplify those automations, when either switch turns on, turn them both on, when either switch turns off, turn both off.
Thanks! I’m now trying this for the ‘on’ automation:
- action:
  - alias: Zet keukenspots aan
      entity_id:
        - switch.relais_keuken_eiland_een
        - switch.relais_keuken_tuindeur_een
    service: switch.turn_on
  alias: koppel inschakeling verlichting keuken doorloop
    - entity_id: switch.relais_keuken_eiland_een
      platform: state
      to: ‘on’
    - entity_id: switch.relais_keuken_tuindeur_een
      platform: state
      to: ‘on’
Manually triggering this from the frontend turns both switches on, so that’s something. However it doesn’t trigger when I toggle either of the switches from off to on.
EDIT: okay, it’s working. Kind off, it takes about 30s before the second relay comes on. Is there any way I can make this leaner so it’s faster? (Or is due to having a busy/large home-assistant install on a rpi3?)
