Meshtastic Infobot
I know this is probably known to a lot of folks already, but here’s an automation you can use to make an auto-reply bot on Meshtastic. I live near a huge city park and I thought it would be nice to have a bot that can provide some information. This would be super helpful in disaster situations where internet is not fully reliable/available.
The automation listens and replies to Direct Messages on meshtastic. If you wanted, you could/probably should restrict this to known specific clients for safety, I suppose.
Prerequisites: You have a meshtastic node connected to home assistant using the Meshtastic integration on HACS. Set your node’s long name to something like “Infobot DM hi to start”
alias: meshtastic weather reply
description: ""
triggers:
  - trigger: event
    event_type: meshtastic_api_text_message
conditions:
  - condition: template
# Note: Replace XXXXXXXXXX with your node number.
# Listen to events and message your node to get this.
    value_template: "{{ trigger.event.data.data.to.node == XXXXXXXXXX }}"
# Make a condition that processes the request.
# There are probably easier ways to do this.
# I have one automation set to reply to hi that tells users this is a bot and what commands are available.
# I then have separate automations for weather, forecast, and time.
  - condition: or
    conditions:
        value_template: "{{ trigger.event.data.data.message == \"weather\" }}"
        value_template: "{{ trigger.event.data.data.message == \"Weather\" }}"
        value_template: "{{ trigger.event.data.data.message == \"What is the weather\" }}"
        value_template: "{{ trigger.event.data.data.message == \"What is the weather?\" }}"
        value_template: "{{ trigger.event.data.data.message == \"what is the weather?\" }}"
        value_template: "{{ trigger.event.data.data.message == \"what is the weather\" }}"
# Meshtastic API examples give it 5 seconds, but 2 seconds seems to be just fine.
actions:
  - delay:
      hours: 0
      minutes: 0
      seconds: 2
      milliseconds: 0
# Change the "abc123def456ghi890" to the device ID of the node you have connected to home assistant and will broadcast replies from. Tip: Switch to the visual editor. This should be one of the only options in the drop-down.
# Keep ack: true.
# These steps are critical. If you use the node number from above here, the automation will ONLY reply to clients with direct connections and strong signals.
  - action: meshtastic.send_text
    metadata: {}
      ack: true
      to: "{{ trigger.event.data.data.from }}"
# The text should be whatever sensor data you want to share with the public. Here's NWS conditions and my acurite weather sensor, which is coming in via rtl_433!
      text: >-
        At home, it is currently {{ states("weather.home")
        | regex_replace("lightning-rainy","Thunderstorms") |
        regex_replace("lightning","Lightning") | regex_replace("sunny","Sunny")
        | regex_replace("partlycloudy","Partly Cloudy") |
        regex_replace("clear-night","Clear") | regex_replace("cloudy","Cloudy")
        | regex_replace("fog","Fog") | regex_replace("hail","Hail") |
        regex_replace("rainy","Rain") }}. It's {{
        states("sensor.acurite_5n1_a_123_f")| round(1)}} °F. With
        {{states("sensor.acurite_5n1_a_123_h")}}% humidity. Winds are
        {{states("sensor.wind_dir") }} at
        {{states("sensor.acurite_5n1_a_123_ws") | round(1) }} mph.
mode: single
Hopefully this is helpful to you and makes Meshtastic way more useful to others!
Thanks for this. Was just starting to think about how to do it and BOOOM you’ve done it already. Great stuff
