Message append time now()
data_template:
message: ‘{%- if is_state(“binary_sensor.door”,“on”)-%}
Front Door Open
{%- else -%}
Front Door Closed
{%- endif -%}
it works perfect
want to add time to message (sent on telegram)
{{now().hour ~ now().strftime(’:%M’)}
Always gives me error
Help?
I think you are just missing the last curly brace.
this works for me:
{{now().hour ~ now().strftime(':%M')}}
How about:
{{ now().timestamp()|timestamp_custom('%H:%M') }}
Or even:
{{now().strftime('%H:%M')}}
Yeah forgot the bracket when pasted code… but that was not the problem.
So how do you merge that in the above function after closee or open text?
data_template:
  message: "Front Door {{ 'Open' if is_state('binary_sensor.door', 'on') else 'Closed' }} at {{ now().strftime('%H:%M') }}"
Or, if you’d rather not have one big line:
data_template:
  message: >
    Front Door {% if is_state('binary_sensor.door', 'on') -%}
      Open
    {%- else -%}
      Closed
    {%- endif %} at {{ now().strftime('%H:%M') }}
Perfect. Thank you. It works.
Now I need to find a way to add a space before at
Now, I know quite a few programming languages… but this one I seem to have some trouble to get it.
Is there a manual, online reference, etc… I could use?
Can you post what you have now? The solutions I provided both have a space before at.
        {%- if is_state("binary_sensor.door","on")-%}
        Front Door Open
        {%- else -%}
        Front Door Closed
        {%- endif -%} at {{ now().strftime('%H:%M') }}
what I get as message is: Closedat hh.mm
That’s because you specified too many dash characters in your jinja statements. The dash character means strip all whitespace in that direction. I very carefully constructed this accordingly:
      Open
    {%- else -%}
      Closed
Notice how there is no dash at the end of {%- endif %}? Also there’s no dash at the beginning of {% if is_state('binary_sensor.door', 'on') -%} for the same reason.
If you want to just fix what you have, then I’d suggest:
        {% if is_state("binary_sensor.door","on") %}
        Front Door Open
        {%- else %}
        Front Door Closed
This strips whitespace (including end of lines) after “Front Door Open” and “Front Door Closed”, but no other whitespace is stripped (except for everything before the first non-whitespace character, which is stripped automatically.)
Awesome.
I missed completely that detail.
I did program with Python before… but never this “script” language… :S
Thanks @pnbruckner
Same here. But I figured this out from other posts, as well as reading:
http://jinja.pocoo.org/docs/dev/templates/#whitespace-control
