Hi guys
I am trying to do a notification automation when one of my smoke sensors fire.
I want the notification to include which sensor fired.
Below is my automation, but I get the following error - can anybody point in the right direction?
Error:
Message malformed: required key not provided @ data[‘trigger’]
Automation
description: ''
- platform: state
entity_id:
- binary_sensor.rogalarm_alrum_smoke_detected
- binary_sensor.rogalarm_gang_smoke_detected
- binary_sensor.rogalarm_garage_smoke_detected
- binary_sensor.rogalarm_loft_smoke_detected
- binary_sensor.rogalarm_stue_smoke_detected
to: detected
for: '0:00:30'
condition: []
- scene: scene.udendors_taend
- service: notify.mobile_app_thomas_telefon
data_template:
title: BRANDALARM!
data: {}
message: '{{ trigger.to_state.name }}' har er detekteret røg!
- service: notify.mobile_app_tines_telefon
data_template:
title: BRANDALARM!
data: {}
mode: parallel
max: 10
Try putting quotes around the whole message e.g.
message: "{{ trigger.to_state.name }} har er detekteret røg!"
In case it is of interest, I use alerts rather than automations for many of my noficiations e.g.
sensor_battery_low:
title: "Information - Battery alert at {{ states('sensor.time') }}"
message: "Check following equipment - {{ state_attr('binary_sensor.battery_alert', 'Below') }}"
channel: Information
entity_id: binary_sensor.battery_alert
state: 'on'
repeat: 1440
can_acknowledge: true
skip_first: true
notifiers:
- mobile_app_sm_g970f
Have you checked the actual binary_sensor
state in Developer Tools?
For motion: on
means motion detected, off
means no motion (clear)
Maybe you need to change clear
to off
and detected
to on
Thanks @Jonah1970 , that seemed to do the trick.
Nice info - where do you create alerts? (I’m rather new at HA
Aaaah! ![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=9)
Just checked - based on the below input, I should actually state On/Off as trigger rather than clear/detected - correct?
Yes. Keep in mind that On
and on
is different. Make sure to always reference the one in Developer Tools.
I have a separate alert.yaml file and the following command in my configuration.yaml to reference it:
alert: !include alert.yaml
Further info is available in the docs …
Thank you very much @ardysusilo
Excellent, @Jonah1970 - I will take a look at it!
Thanks you for your input!
