Messages not sending via telegram bot (Doorbell notification using picamera, mqtt and telegram)
I’m very noob when comes to home automation, I’m trying to send a message to my android device via telegram. Now I’ve setup my configuration as follows. Most of the code is compiled together from someone else’s projects. because I don’t know anything about homeassistant,.
notify:
    - platform: telegram
      chat_id: xxxxxxxx
telegram_bot:
  - platform: polling
    api_key: yyyyyyyyyyy:some_thing_somet_hing_here.
    allowed_chat_ids:
      - xxxxxxxxxxx
mqtt:
#this is empty here
automation:
    - alias: Doorbell_pressed_automation
        platform: mqtt
        topic: dev/test
        payload: 'Capture!'
        - service: automation.turn_off
          entity_id: automation.doorbell_pressed_automation
        - service: script.turn_on
          entity_id: script.doorbell_pressed_script
        - delay: "00:00:5"
        - service: automation.turn_on
script:
    doorbell_pressed_script:
      alias: 'notify me'
      sequence:
        - service: notify.telegram
            title: Home Assistant Notification
            message: --Doorbell Pressed--
              photo:
                - url: http://192.168.0.103/images/image.jpg
                  caption: Doorbell View
    dev_publish_on_script:
      sequence:
        - service: mqtt.publish
          data: {"topic":"dev/test", "payload":"ON"}
    test_telegram:
        alias: 'test_telegram'
        sequence:
              title: TEST Message
              message: 'This is a test!'
                photo:
that was all about the homeassistant configuration, now there is an mqtt script that runs with nohup, publishes to the dev/test and dev/camera. Here’s the script.
import RPi.GPIO as GPIO
import picamera
import paho.mqtt.client as mqtt
import paho.mqtt.publish as publish
import argparse
import signal
import sys
import time
import logging
import datetime
### camera
camera = picamera.PiCamera()
camera.vflip=True
#mqtt
broker = '192.168.0.103'
topic = 'dev/test'
mqttQos = 0
mqttRetained = False
# setup for taking input from switch
GPIO.setmode(GPIO.BCM)
GPIO.setup(17, GPIO.IN, pull_up_down = GPIO.PUD_UP)
prev_input = 0
def on_connect(client, userdata, flags, rc):
   print("Connected with result code "+str(rc))
   client.subscribe(topic)
# The callback for when a PUBLISH message is received from the server.
def on_message(client, userdata, msg):
   payload = str(msg.payload.decode('ascii'))  # decode the binary string
   print(msg.topic + " " + payload)
   process_trigger(payload)
client = mqtt.Client()
client.on_connect = on_connect    # call these on connect and on message
client.on_message = on_message
client.username_pw_set(username='pi',password='user_pass')  # need this
client.connect(broker)
client.loop_start()    #  run in background and free up main thread
def post_image():
   print('Taking photo')
   camera.capture('image.jpg')
   file_name = 'image_' + str(datetime.datetime.now()) + '.jpg'
   camera.capture(file_name)  # time-stamped image # create an object for this file and then pass the object here
   with open('image.jpg', "rb") as imageFile:
       myFile = imageFile.read()
       data = bytearray(myFile)
   client.publish('dev/camera', data, mqttQos, mqttRetained)  #
   client.publish('dev/test', 'Capture!')
   print(file_name + 'image published')
while True:
        input = GPIO.input(17)
        if ((not prev_input) and input):
            post_image()
            time.sleep(2)
        prev_input = input
        time.sleep(0.2)
This script takes the picture whenever I press the switch, saves it with a timestamp and image.jpg.
This is to be sent via the bot.
What I can’t figure out is, why isn’t telegram bot sending any notification/image/message on my device?
Any help is much appreciated.
Any error messages in the log?
To start troubleshooting I’d make sure a normal text message goes thorough first, then try to attach the picture and caption.
Yes, I just tried sending text messages, it works with them.
But when sending an image file, it gives an error of urllib3.
Also, I’m able to access the file through browser, and the files name is correct.
Can you paste the whole error message?
It’s probably above my head but I’m sure someone will be able to work it out :slight_smile:
It worked fine with a photo, but then again it started giving the same error again,
[2:57 PM, 11/27/2017] Prince: ERROR (Thread-6) [homeassistant.components.telegram_bot] Error sending file: urllib3 HTTPError ('Connection aborted.', timeout('Th
I don’t understand why timeout error is there, the network is fine.
