I just started with HASS this week. My system auto discovered Plex. I found my token and entered it, but I didn’t put “true” in the secure connection field. It processed and then went away, but I can’t find Plex as an entity and it isn’t in my config file. I can’t figure out where I can add the missing info or start over.
Thanks. I was able to use the configurator add on to make the changes. I confirmed the IP address and token and set the SSL settings both to false with no luck. I also tried true and that didn’t work either.
I also tried entering the following entry in the config file to see if that would help (copied from the Plex component page).
To view the logs in the Developer tools section click the far right icon, the i in the circle. That will should have the info your looking for. Also there is a Load Full Home Assistant Log button at the bottom of this screen.
Thanks, I was starting to notice all kinds of strange behaviors with my system. Plex wasn’t working properly, map wasn’t showing the correct location even after updating lat/long, units were mixed between F and C on the weather. Ring quit working. I finally decided that since I didn’t have much time invested yet, so I just did a clean install. Now everything seems to be working correctly. I have Plex, Ring, Dark Sky, Z Wave, etc. all working as they should. Ran it over night and everything is still functioning with no errors.
Hopefully now that I have a better understanding of changing the configuration and reading the logs I can make some more progress on my system.
