hi guys after upgrading from 0.111.1 to 0.111.3 the met.no weather stop working , already uninstall the integration and add it again still no luck , any one else having this problem?
in my other home assistant with 0.111.1 its working fine
perfect its fix appreciate all the work
Hi, funnily enough it was just a coincidence it stopped working when you upgraded. The thing was, that met.no at the same time changed their API, so it seemed there was a causal relation between the two events, although this was absolutely not the case.
