My point is the use of home assistant for a camper van (rv) travelling through Europe. So the location is changing often, sometimes every day. Using a gps-sensor it is easy to change the home-zone with the consequence to see the correct map and also correct sun rise calculation. But the weather forecast with the met.no integration is not changing. For changing the coordinates in met.no integration it is necessary to delete and reinstall the integration. I’m interesting in a solution, so that met.no uses the current coordinates of the homeassistant core system. So the weather forecast would be following the current camper position. This would be also comfortable for static implementations (normal, not moving homes) in case of correction in zone-details, because these would also no longer be adopted after the installation of the integration.
