Met.no state : unknown
From today, my HA cannot access any data from met.no.
What I know :
  • They have a new homepage
What I do not know:
  • How can I get any data from the new page?
Any idea? Thanks!!!
Same here. Since 17:27 (four hours ago) the state is on “unknown”.
I’ve experienced the same problem (with the yr platform, which appears to use the same data source as the met, aka Met.no, platform.) Not sure I fully understand what’s going on, or what the ultimate plan is (although it does look like it’s being worked on.) You might want to checkout:
Same here. Hoorn NL and Prague both says UNKNOWN now :sob:
Looks like the Met.no integration was fixed (in PR #36880) and will be in 0.111.4. However, looks like the older yr platform was overlooked. It needs a similar fix.
EDIT: I just submitted PR #36889.
EDIT 2: Looks like the fix for yr will also be in 0.111.4. :slight_smile:
Thank you the info. I updated to 0.111.4 and I got back the original functionality :slight_smile: !!!
Thanks!!!
