You should use some of the SUMMARY sensors, for example (i’m using dark sky) i have: sensor.dark_sky_daily_summary
and its state is: Light rain tomorrow, with high temperatures falling to 22°C tomorrow.
Same for the weekly for example (i’m using yweather) and it holds weekly forecast as an array of objects.
Hi, thanks for your reply.
The question is wether Met.no have this option or not. I used the Darkysky sensor before, but it is limited to API usage, hence using Met.no.
