Met office integration failed to connect
I have obtained the api key from Met office (https://register.metoffice.gov.uk/MyAccountClient/account/view) however I keep getting failed to connect in HA 114.2 from the integration page.
Is this not working or does it take something like 24 hrs to get activated? It has been several hours since I created the account.
I have the same problem seems the api delivered but, the connection is denied to the services. Home Assistant 2020.12.1
Did one of you already solved this? I have the same issue with hass 2020.12.2
Nah gave up on it and just use the met.no default integration
I have the latest version of 2021.4.3 and I can also connect.
Please write someone to support, I can’t be English.
Thank you
Did she join someone? I still have the same problem with connecting
Hi. I’m having the same issue, did anyone find a solution?
