Metabase Add-on for Home Assistant
Hi! I created the Metabase Add-on for Home Assistant.
It’s a nice tool to dig into data, for example your Home Assistant data when you use the recorder integration or you can explore the data created with my DSMR Reader Add-on.
See installation instructions here: hassio-addons/metabase at main · sanderdw/hassio-addons · GitHub
2026-05-03: 1.3.0 Update to Metabase 0.60.3
Changelog here
A tip for everyone that use zwaveJS: change you port to something else then 3000.
it’s starting now and I’m gonna play with it! thanks!
2021-03-13: 0.0.2 Metabase v0.38.1
2021-03-18: 0.1.1 Metabase v0.38.2
2021-04-04: 0.1.2 Update to Metabase 0.38.3
2021-04-21: 0.2.0 Update to Metabase 0.39.0.1
2021-05-06: 0.2.1 Update to Metabase 0.39.1
2022-04-17: 0.4.0 Update to Metabase 0.42.4
Changelog here
2025-01-03: 0.4.0 Update to Metabase 0.52.4
Changelog here
2025-01-05: 1.0.1
Changelog here
1.0.1
  • Fix version check
  • Beta Arm support, the HEAD of development on the Metabase repository, use at your own risk. Will be replaced with the official Metabase provided ARM Release later.
  • NOTE: Standard database type is changed to h2 to remove the dependency on an external database/addon.
    Using Metabase with an H2 application database is not recommended for production deployments. For production deployments, we highly recommend using Postgres instead. If you decide to continue to use H2, please be sure to back up the database file regularly (stored in the backup folder of HA).
2025-03-10: 1.1.0 Update to Metabase 0.53.5.5 and official ARM Support
Changelog here
Will you continue keeping the add-on updated? Just checkingn before starting to use it.
Yes i am, good to see that there is still interest :slightly_smiling_face:. I will create some time to develop an update.
2025-10-23: 1.2.0 Update to Metabase 0.56.11
Changelog here
Changelog here
