Just a quick issue, it seems entities created while using Météo France integration does not use the correct naming for some Paris “arrondissement”.
If you try to create an integration using zip code 75008, everything seems fine except entities created are named using 75017 zipcode…
Using other zipcode seems fine, so it is really strange.
Any idea of what I can do ( except manually renaming all entities) ?
