Hey there
I have a “water clock” i like to integrate with home assisant. I am not sure how do it. It this type:
Can i use something like this: Homematic IP Schnittstelle f?r Smart Meter (HmIP-ESI-IEC) (wei?) - Digitec
Greets Chris
Hey there
Greets Chris
Hi
Seems that you will need an M-Bus interface 868 Mhz.
I just started my research this morning so I havent tested or validated anything.
My meter is a GWF type DE-12-MI001-PTB010.
I will cntinue my researches and keep you updated.
Denis
https://www.homewizard.com/nl/shop/wi-fi-watermeter/ is the water meter i use for the same watermeter. This integration is fully compatible with home assistent without using MQTT
