I have setup the MFA to secure remote access from the HA Android app installed in my smartphone.
The Profile menu in the UI has one choice for both local and remote acces but I would like to setup MFA only for remote access as this is a bit annoying in case of local access.
Please can you make a MFA choice in the UI/Profile to propose MFA for local or remote access or for both ?
Hi, you could use a workaround to use different profiles (users) & dashboards for your Android device (when away) and another for @home when using another device.
Just an idea…
Nope, not a good suggestion !
First of all, you’ll have to switch user on your device when home or away
Second the unprotected user will also be available - and not protected by MFA - from the outside
