Home Assistant release (hass --version):
0.20.3
Python release (python3 --version):
Python 3.4.3
Component/platform:
mFi
Description of problem:
Only the older mfi gear and in wall outlets are supported. There is currently not support for the mFi-LD in wall dimmable light switch
Expected:
Support for mFi-LD
Problem-relevant configuration.yaml entries and steps to reproduce:
Just simply not supported.
Traceback (if applicable):
Additional info:
If you have another way to make this work please let me know. I have been able to get the on/off to work with command-line but I cannot get a slider to work with the command line. At least that I can figure out. If support was just built into this it would work and look much better.
Thanks!
