Mi Flora plant monitor sensor lux readings
I just got 4 Mi Flora plant sensors and I get some large negative spikes for lux readings.
Anyone know if it is a hardware issue or home assistant issue?
And if those values should just be flipped to positives or discarded altogether.
Edit: On latest Hassbian btw.
Noticed the same on mine, they havenā€™t done this before - itā€™s a new thing.
Well thatā€™s certainly a strange coincidence.
It happens to me every now and then.
Easiest solution is to use a filter sensor.
Just making and assumption but are you using them with the plant monitor?
Allright Iā€™ll just set a filter.
Actually I didnā€™t even know about the Plant monitor component. But now I will try it out, so thank you for that :slight_smile:
Havenā€™t added filter sensors to mine yet but here are some examples of mine.
Nice. I like the compact view of the plant card. But the icon for conductivity should be changed ^^.
Maybe to mdi:sigma-lower.
This was a known issue and since fixed:
hereā€™s the specific issue:
Should be in the next RC I think. It was merged here:
Thanks a lot!
noticed the same, and wanted to open a new topic :wink:
great news, that itā€™s addressed and solved already, but please ignore my ignorance, what does RC stand for in this context?
if itā€™s ā€œrelease candidateā€: RC of what? hass? or a special library?
