Mi Light LED Controler
Hi, I’m trying to integrate an LED strip.
I am using Zigbee Automation as integration and I have Mi-Light LED zigbee controller https://www.amazon.com/Contoller-DC12-24V-MiBoxer-Control-FUT037Z/dp/B09P4176VD?th=1 for the LED strip. I will be able to integrate the LED strip into the home assistant. However, I can only change the light intensity, but the strip itself cannot be turned off from home assistant.
