Hi all,
anybody with this led strip wifi controller that succeeded in make it work with our home assistant?
PS if not, any alternative 24V RGB-CCT controller that works out of the box ?
Hi all,
Just added the suggested limitlessled configuration but it looks like limitlessled is not configured. Do I have to install any addon? I didn’t find any
Push
I am facing the same problem. Have you found a solution?
Try tuyalocal
how to use it? You need to customize the firmware of the WL5?
