There are options for connecting bluetooth devices to the Home Assistant
But since I am using HAOS version 2023.9.2, the instructions are partially not suitable, although the essence is the same. I will share my implementation of connecting Mi Portable Bluetooth Speaker XMYX04WM to HAOS
You do not need to install anything in HAOS version 2023.9.2, just use what is already in HAOS. It is done through the SSH addon terminal
Do the column pairing first as written in this documentation
Pairing
Using bluetoothctl
Begin by starting bluetoothctl and follow these basic steps:
$ bluetoothctl
The prompt should display:
[bluetooth]#
List the available controllers:
[bluetooth]# list
Display information about a controller:
[bluetooth]# show controller_mac_address
Set the default controller:
[bluetooth]# select controller_mac_address
Power on the controller:
[bluetooth]# power on
Enable the agent and set it as default:
[bluetooth]# agent on
[bluetooth]# default-agent
Set the controller as discoverable (temporarily for 3 minutes) and pairable:
[bluetooth]# discoverable on
[bluetooth]# pairable on
Scan for devices:
[bluetooth]# scan on
Put the device into pairing mode. This generally involves pressing a button or a combinations of buttons, usually for several seconds.
Discover the device MAC address:
[bluetooth]# devices
Pair with the device:
[bluetooth]# pair device_mac_address
Enter the PIN if prompted:
[agent] PIN code: ####
Trust the device:
[bluetooth]# #trust device_mac_address
Connect to the device:
[bluetooth]# connect device_mac_address
Display information about the device:
[bluetooth]# info device_mac_address
The device is now paired:
[bluetooth]# quit
The Mi Portable Bluetooth Speaker XMYX04WM knows how to transmit battery level and you can see that, and you can also see the states of the speaker, which I use in my variant as sensors and controls
Output detailed information about the device with the command, where XX:XX:XX:XX:XX:XX is your mac address of the device
bluetoothctl info XX:XX:XX:XX:XX:XX
If you don’t see Battery Percentage in the row, you need to enable an experimental feature that will report the battery level of your device. Read more about it here
You can pre-install the nano package with the command if it is not installed
apk add nano
Open the main.conf file at the path /etc/bluetooth/main.conf
nano /etc/bluetooth/main.conf
And add a line at the very top
Experimental=true
This is what it should look like
[General]
Experimental=true
Save the changes in the main.conf file and exit
Run the command again and see if the string Battery Percentage appears.
Next, create sensors and switch, where XX:XX:XX:XX:XX:XX is your mac address of the device. Before creating sensors, you can check whether the commands output yes or no answers and battery level.
#Command line Sensor https://www.home-assistant.io/integrations/sensor.command_line
command_line:
- sensor:
name: Mi Portable Bluetooth Speaker Battery Level
unique_id: mi portable bluetooth speaker battery level
command: bluetoothctl info XX:XX:XX:XX:XX:XX | grep "Battery Percentage" | cut -d ' ' -f4 | sed 's/^.//;s/.$//'
scan_interval: 10
device_class: battery
- binary_sensor:
name: Mi Portable Bluetooth Speaker Power
unique_id: mi portable bluetooth speaker power
command: l2ping -c 1 XX:XX:XX:XX:XX:XX > /dev/null 2>&1 && echo yes || echo no
scan_interval: 5
payload_on: "yes"
payload_off: "no"
- binary_sensor:
name: Mi Portable Bluetooth Speaker Connected
unique_id: mi portable bluetooth speaker connected
command: bluetoothctl info XX:XX:XX:XX:XX:XX | grep "Connected" | cut -d ' ' -f2
scan_interval: 10
device_class: connectivity
payload_on: "yes"
payload_off: "no"
- binary_sensor:
name: Mi Portable Bluetooth Speaker Paired
unique_id: mi portable bluetooth speaker paired
command: bluetoothctl info XX:XX:XX:XX:XX:XX | grep "Paired" | cut -d ' ' -f2
scan_interval: 10
payload_on: "yes"
payload_off: "no"
- binary_sensor:
name: Mi Portable Bluetooth Speaker Bonded
unique_id: mi portable bluetooth speaker bonded
command: bluetoothctl info XX:XX:XX:XX:XX:XX | grep "Bonded" | cut -d ' ' -f2
scan_interval: 10
payload_on: "yes"
payload_off: "no"
- binary_sensor:
name: Mi Portable Bluetooth Speaker Trusted
unique_id: mi portable bluetooth speaker trusted
command: bluetoothctl info XX:XX:XX:XX:XX:XX | grep "Trusted" | cut -d ' ' -f2
scan_interval: 10
payload_on: "yes"
payload_off: "no"
- binary_sensor:
name: Mi Portable Bluetooth Speaker Blocked
unique_id: mi portable bluetooth speaker blocked
command: bluetoothctl info XX:XX:XX:XX:XX:XX | grep "Blocked" | cut -d ' ' -f2
scan_interval: 10
payload_on: "yes"
payload_off: "no"
- switch:
name: Mi Portable Bluetooth Speaker Connection
unique_id: mi portable bluetooth speaker connection
scan_interval: 10
command_on: bluetoothctl connect XX:XX:XX:XX:XX:XX
command_off: bluetoothctl disconnect XX:XX:XX:XX:XX:XX
command_state: bluetoothctl info XX:XX:XX:XX:XX:XX | grep "Connected" | cut -d ' ' -f2
value_template: '{{ value == "yes" }}'
icon: >
{% if value == "yes" %} mdi:bluetooth-connect
{% else %} mdi:bluetooth-off
{% endif %}
#Template https://www.home-assistant.io/integrations/template/
template:
- sensor:
- name: 'Mi Portable Bluetooth Speaker'
state: '{{ states("binary_sensor.mi_portable_bluetooth_speaker_power") }}'
icon: >
{% if is_state("binary_sensor.mi_portable_bluetooth_speaker_power", "on") %}
mdi:bluetooth
{% else %}
mdi:bluetooth-off
{% endif %}
attributes:
Battery: '{{ states("sensor.mi_portable_bluetooth_speaker_battery_level") }}'
Connected: '{{ states("binary_sensor.mi_portable_bluetooth_speaker_connected") }}'
Paired: '{{ states("binary_sensor.mi_portable_bluetooth_speaker_paired") }}'
Bonded: '{{ states("binary_sensor.mi_portable_bluetooth_speaker_bonded") }}'
Trusted: '{{ states("binary_sensor.mi_portable_bluetooth_speaker_trusted") }}'
Blocked: '{{ states("binary_sensor.mi_portable_bluetooth_speaker_blocked") }}'
#This is to hide or display the player card. This is used in the card condition
#input_boolean:
mi_portable_bluetooth_speaker_control_panel_1:
name: "Mi Portable Bluetooth Speaker Control Panel 1"
icon: mdi:menu
To output sound to the speaker, install the MPD addon
In the Home Assistant add-on store, manually add the following repository URL
https://github.com/Poeschl/Hassio-Addons
Next, read the description in the documentation about creating your own custom mpd.conf file
Open the mpd.conf file at /share/mpd/mpd.conf and add the following
music_directory "/media/Music" #Путь к музыке любой
playlist_directory "/media/Playlists" #Путь к плейлисту любой
db_file "/data/database/mpd.db" #Не меняем путь
#In the name line, enter a device name that you understand
#In the sink line specify the mac address of your device. Replace XX_XX_XX_XX_XX_XX with your #device's mac address
audio_output {
type "pulse"
name "Pulse Mi Portable Bluetooth Speaker"
sink "bluez_sink.XX_XX_XX_XX_XX_XX.a2dp_sink"
В configuration.yaml добавляем
media_player:
- platform: mpd
name: "MPD Mi Portable Bluetooth Speaker"
host: localhost
port: 6600
Create a card where all the information is displayed, and also make a hiding media card, it can appear after turning on the column or manually. Here it is at your discretion
Card code
type: vertical-stack
cards:
- type: vertical-stack
cards:
- type: entities
entities:
- entity: sensor.mi_portable_bluetooth_speaker
name: Mi Bluetooth Speaker
type: custom:multiple-entity-row
show_state: false
secondary_info:
attribute: Battery
entities:
- entity: switch.mi_portable_bluetooth_speaker_connection
icon: mdi:bluetooth-connect
state_color: true
type: button
tap_action:
action: toggle
styles:
height: 60px
width: 60px
- entity: binary_sensor.mi_portable_bluetooth_speaker_power
icon: mdi:bluetooth
state_color: true
styles:
height: 60px
width: 60px
- entity: input_boolean.mi_portable_bluetooth_speaker_control_panel_1
icon: mdi:music
state_color: true
type: button
tap_action:
action: toggle
styles:
height: 60px
width: 60px
- type: conditional
conditions:
state: 'on'
state: 'on'
card:
type: custom:mushroom-media-player-card
entity: media_player.mpd_mi_portable_bluetooth_speaker
fill_container: false
use_media_info: false
show_volume_level: false
volume_controls:
- volume_set
media_controls:
- play_pause_stop
- next
- previous
- on_off
layout: vertical
collapsible_controls: false
Текст на русском (Text in Russian )
Есть варианты подключения bluetooth девайсов к Home Assistant
Но так как я использую HAOS version 2023.9.2, то инструкции частично не подходят, хотя суть одинаковая. Я поделюсь своей реализацией подключения Mi Portable Bluetooth Speaker XMYX04WM к HAOS
Устанавливать в HAOS version 2023.9.2 ничего не нужно, просто будем использовать то, что и так заложено в HAOS. Делается через терминал аддона SSH
Сделайте сначала спаривание колонки как написано в этой документации
Pairing
Using bluetoothctl
$ bluetoothctl
[bluetooth]#
[bluetooth]# list
Scan for devices:
Trust the device:
[bluetooth]# quit
Колонка Mi Portable Bluetooth Speaker XMYX04WM умеет передавать уровень заряда аккумулятора и это можно увидеть, а также можно увидеть состояния колонки, которые я использую в своем варианте в качестве сенсоров и управления
Выводим детальную информацию об устройстве командой, где XX:XX:XX:XX:XX:XX это ваш мак адрес устройства
Если в строке не увидели Battery Percentage, то нужно включить экспериментальную функцию, которая будет сообщать об уровне заряда батареи устройства. Подробнее об этом читаем здесь
Предварительно можете установить пакет nano командой, если он не установлен
apk add nano
Откроем файл main.conf по пути /etc/bluetooth/main.conf
И добавим в самый вверх строчку
Experimental=true
Вот так должно выглядеть
[General]
Experimental=true
Сохраняем изменения в файлике main.conf и выходим
Повторно проверяем запускаем команду и смотрим, появилась ли строка Battery Percentage
Дальше создаем сенсоры и выключатель, где XX:XX:XX:XX:XX:XX это ваш мак адрес устройства. Перед созданием сенсоров, предварительно можете проверить, выводят ли команды ответы да или нет и уровень заряда батареи
command_line:
- sensor:
scan_interval: 10
- binary_sensor:
scan_interval: 5
payload_on: "yes"
payload_off: "no"
- binary_sensor:
scan_interval: 10
payload_on: "yes"
payload_off: "no"
- binary_sensor:
scan_interval: 10
payload_on: "yes"
payload_off: "no"
- binary_sensor:
scan_interval: 10
payload_on: "yes"
payload_off: "no"
- binary_sensor:
scan_interval: 10
payload_on: "yes"
payload_off: "no"
- binary_sensor:
scan_interval: 10
payload_on: "yes"
payload_off: "no"
- switch:
scan_interval: 10
icon: >
{% endif %}
template:
- sensor:
icon: >
mdi:bluetooth
{% else %}
mdi:bluetooth-off
{% endif %}
attributes:
#Это нужно для того, чтобы скрыть или отобразить карточку плеера. Это используется в #карточке условие
input_boolean:
icon: mdi:menu
Для вывода звука на колонку устанавливаем аддон MPD
В магазин дополнений Home Assistant вручную добавьте следующий URL-адрес репозитория
Далее читаем описание в документации о создании своего пользовательского файла mpd.conf
Открываем файлик mpd.conf по пути /share/mpd/mpd.conf и добавляем следующее
#Тут указываем
#В строке name укажите понятное вам имя устройства
#В строке sink указываем мак адрес вашего девайса. Замените XX_XX_XX_XX_XX_XX на свой #мак адрес устройства
audio_output {
type "pulse"
media_player:
- platform: mpd
host: localhost
port: 6600
Создаем карточку, где выводится вся информация, а также делаем скрывающуюся медиа карточку, она может появляться после включения колонки или вручную. Тут на ваше усмотрение
Код карточки
cards:
cards:
- type: entities
entities:
show_state: false
secondary_info:
attribute: Battery
entities:
state_color: true
type: button
tap_action:
action: toggle
styles:
height: 60px
width: 60px
icon: mdi:bluetooth
state_color: true
styles:
height: 60px
width: 60px
icon: mdi:music
state_color: true
type: button
tap_action:
action: toggle
styles:
height: 60px
width: 60px
- type: conditional
conditions:
state: 'on'
state: 'on'
card:
volume_controls:
- volume_set
media_controls:
- play_pause_stop
- next
- previous
- on_off
layout: vertical
