Hi there.
This in my first topic. Hope it’s not in wrong place.
So i have Intel NUC with fresh setup:
Home Assistant OS 8.1
core-2022.6.2
SONOFF ZB Dongle-P USB Dongle Plus Zigbee 3.0 2652P chip. (was on firmware 20210708 originally. Today have flashed to 20220507)
Miboxer FUT035Z - 12V dimmer which have a problem. If I switch off it’s power for a few minutes, it will not work anymore.
warning 2022-06-01 09:02:49Device 'light' left the network
info 2022-06-01 09:02:49MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"light","ieee_address":"0xa4c138be90c35d78"},"type":"device_leave"}'
So to fix it i just have to click “permit join all” and wait a few seconds:
debug 2022-06-01 09:03:11Received MQTT message on 'zigbee2mqtt/bridge/request/permit_join' with data '{"device":null,"time":254,"transaction":"ecqbl-1","value":true}'
info 2022-06-01 09:03:11Zigbee: allowing new devices to join.
info 2022-06-01 09:03:11MQTT publish: topic 'zigbee2mqtt/bridge/response/permit_join', payload '{"data":{"time":254,"value":true},"status":"ok","transaction":"ecqbl-1"}'
info 2022-06-01 09:03:21Device 'light' joined
info 2022-06-01 09:03:21MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"light","ieee_address":"0xa4c138be90c35d78"},"type":"device_joined"}'
info 2022-06-01 09:03:21Starting interview of 'light'
info 2022-06-01 09:03:21MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"light","ieee_address":"0xa4c138be90c35d78","status":"started"},"type":"device_interview"}'
debug 2022-06-01 09:03:21Device 'light' announced itself
info 2022-06-01 09:03:21MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"friendly_name":"light","ieee_address":"0xa4c138be90c35d78"},"type":"device_announce"}'
debug 2022-06-01 09:03:22Received Zigbee message from 'light', type 'readResponse', cluster 'genBasic', data '{"stackVersion":0}' from endpoint 1 with groupID 0
debug 2022-06-01 09:03:22Received Zigbee message from 'light', type 'readResponse', cluster 'genBasic', data '{"dateCode":""}' from endpoint 1 with groupID 0
debug 2022-06-01 09:03:22Received Zigbee message from 'light', type 'readResponse', cluster 'genBasic', data '{}' from endpoint 1 with groupID 0
info 2022-06-01 09:03:22Successfully interviewed 'light', device has successfully been paired
info 2022-06-01 09:03:22Device 'light' is supported, identified as: Miboxer Dual white LED controller (FUT035Z)
info 2022-06-01 09:03:22MQTT publish: topic 'zigbee2mqtt/bridge/event', payload '{"data":{"definition":{"description":"Dual white LED controller","exposes":[{"features":[{"access":7,"description":"On/off state of this light","name":"state","property":"state","type":"binary","value_off":"OFF","value_on":"ON","value_toggle":"TOGGLE"},{"access":7,"description":"Brightness of this light","name":"brightness","property":"brightness","type":"numeric","value_max":254,"value_min":0},{"access":7,"description":"Color temperature of this light","name":"color_temp","presets":[{"description":"Coolest temperature supported","name":"coolest","value":153},{"description":"Cool temperature (250 mireds / 4000 Kelvin)","name":"cool","value":250},{"description":"Neutral temperature (370 mireds / 2700 Kelvin)","name":"neutral","value":370},{"description":"Warm temperature (454 mireds / 2200 Kelvin)","name":"warm","value":454},{"description":"Warmest temperature supported","name":"warmest","value":500}],"property":"color_temp","type":"numeric","unit":"mired","value_max":500,"value_min":153}],"type":"light"},{"access":2,"description":"Triggers an effect on the light (e.g. make light blink for a few seconds)","name":"effect","property":"effect","type":"enum","values":["blink","breathe","okay","channel_change","finish_effect","stop_effect"]},{"access":1,"description":"Link quality (signal strength)","name":"linkquality","property":"linkquality","type":"numeric","unit":"lqi","value_max":255,"value_min":0}],"model":"FUT035Z","options":[{"access":2,"description":"Controls the transition time (in seconds) of on/off, brightness, color temperature (if applicable) and color (if applicable) changes. Defaults to `0` (no transition).","name":"transition","property":"transition","type":"numeric","value_min":0},{"access":2,"description":"When enabled colors will be synced, e.g. if the light supports both color x/y and color temperature a conversion from color x/y to color temperature will be done when setting the x/y color (default true).","name":"color_sync","property":"color_sync","type":"binary","value_off":false,"value_on":true}],"supports_ota":false,"vendor":"Miboxer"},"friendly_name":"light","ieee_address":"0xa4c138be90c35d78","status":"successful","supported":true},"type":"device_interview"}'
info 2022-06-01 09:03:22Configuring 'light'
debug 2022-06-01 09:03:22Received Zigbee message from 'light', type 'readResponse', cluster 'lightingColorCtrl', data '{"colorCapabilities":16}' from endpoint 1 with groupID 0
debug 2022-06-01 09:03:22Missing colorTempPhysicalMin and/or colorTempPhysicalMax for endpoint 0xa4c138be90c35d78!
info 2022-06-01 09:03:22MQTT publish: topic 'zigbee2mqtt/light', payload '{"color_mode":"xy","linkquality":78,"state":null}'
debug 2022-06-01 09:03:22Received Zigbee message from 'light', type 'readResponse', cluster 'lightingColorCtrl', data '{"colorTempPhysicalMax":500,"colorTempPhysicalMin":153}' from endpoint 1 with groupID 0
info 2022-06-01 09:03:22MQTT publish: topic 'zigbee2mqtt/light', payload '{"color_mode":"xy","linkquality":75,"state":null}'
info 2022-06-01 09:03:22Successfully configured 'light'
debug 2022-06-01 09:03:24Received Zigbee message from 'light', type 'commandActiveStatusReport', cluster 'manuSpecificTuya', data '{"dpValues":[{"data":{"data":[255,255,255,206],"type":"Buffer"},"datatype":2,"dp":81}],"seq":256}' from endpoint 1 with groupID 0
debug 2022-06-01 09:03:24No converter available for 'FUT035Z' with cluster 'manuSpecificTuya' and type 'commandActiveStatusReport' and data '{"dpValues":[{"data":{"data":[255,255,255,206],"type":"Buffer"},"datatype":2,"dp":81}],"seq":256}'
The same time another 220v relay works fine after power outage. I don’t have many devices to test, only 1 button, 1 dimmer and a few relays.
Any help will be appreciate!
Thanks in advance!!
