Hello to you all,
How to connect new led strip controller Miboxer WL5 with Home assistant.
I’ve tried all of options given with limitlessled. But it does not work.
Hello to you all,
Im also looking for solution for Miboxer WL5.
You can add the device into the tuya cloud and then integrate tuya on homeassistant. It works well except for the light effects.
Anyone got a new / better solution?
Hi,I also searching other metods. Not tuya integration
The more that I tried to add by integrating tuya. Unfortunately, the login details were incorrect each time and then no connection.
