You need to search for stationId: no stationID: this is done in the web developer tools in the inspector tab… When you search for stationId then you will get a 32 Hex. Hope this helps
For those who have node-red installed on Home Assistant I wrote this flow which is way easier then a script:
"id": "90236b67.e1466",
"type": "inject",
"z": "692a85b207f3c084",
"name": "",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "*/15 8-21 * * *",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payloadType": "date",
"x": 310,
"y": 160,
"wires": [
"413272a1.c40e84"
"id": "413272a1.c40e84",
"type": "http request",
"name": "Envertech",
"method": "POST",
"ret": "txt",
"paytoqs": "ignore",
"url": "https://www.envertecportal.com/ApiStations/getStationInfo?stationId=IMPORTANT ADD 32 DIGIT ID HERE",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"credentials": {
"user": "",
"password": ""
"x": 480,
"y": 160,
"wires": [
"855b5f6.0b7092"
"id": "855b5f6.0b7092",
"type": "json",
"name": "",
"property": "payload",
"action": "",
"pretty": false,
"x": 290,
"y": 240,
"wires": [
"ffe8e97f.8cf26",
"7566c765e37a9b59"
"id": "ffe8e97f.8cf26",
"type": "ha-entity",
"name": "CurrentPower",
"server": "cbb458bc.e8ad88",
"version": 1,
"debugenabled": true,
"outputs": 1,
"entityType": "sensor",
"config": [
"property": "name",
"value": "solar.currentpower"
"property": "device_class",
"value": ""
"property": "icon",
"value": "mdi:solar-panel"
"property": "unit_of_measurement",
"value": "W"
"state": "payload.Data.Power",
"stateType": "msg",
"attributes": [],
"resend": true,
"outputLocation": "",
"outputLocationType": "none",
"inputOverride": "allow",
"outputOnStateChange": false,
"outputPayload": "$entity().state ? \"on\": \"off\"",
"outputPayloadType": "jsonata",
"x": 460,
"y": 240,
"wires": [
"id": "7566c765e37a9b59",
"type": "function",
"name": "",
"func": "var payload=msg.payload.Data.UnitETotal;\nmsg.payload=parseFloat(payload.substring(0, payload.length - 4));\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 280,
"y": 320,
"wires": [
"c8d65c0d.51b59"
"id": "c8d65c0d.51b59",
"name": "solarPower",
"version": 1,
"outputs": 1,
"config": [
"property": "name",
"value": "solarPower"
"value": "energy"
"property": "icon",
"value": "kWh"
"state": "payload",
"stateType": "msg",
"attributes": [
"property": "state_class",
"value": "measurement",
"valueType": "str"
"property": "last_reset",
"value": "2020-05-13T22:00:00+00:00",
"valueType": "str"
"resend": true,
"x": 450,
"y": 320,
"wires": [
