greenleaf
(greenleaf)
August 8, 2022, 4:20pm
1
There’s a working esphome template for the M5 ATOM Echo device here:
Has anyone tried adding microphone support for this device? My goal here is to use it as an input device for the Hey Ada voice assistant.
EDIT: Looks like I’m not the only one. The current state is that I2S output is supported but doesn’t look like input is yet.
opened 02:29PM - 09 Jun 21 UTC
integration: media_player
<!-- READ THIS FIRST:
- This is for feature requests only, for issues please g… o to the issues repository.
- Please be as descriptive as possible, especially use-cases that can otherwise not be solved boost the problem's priority.
DO NOT DELETE ANY TEXT from this template! Otherwise the issue may be closed without a comment.
**Describe the problem you have/What new integration you would like**
It would be great to have ESPHome support for an I2S (I²S) microphone like the one on the [LILYGO® TTGO T-Camera](https://www.aliexpress.com/item/4000138976452.html).
This specific model came with a demo firmware that had a [voice command](https://youtu.be/HytrNvt0WT4) to activate the camera. I don't know if there's any source available for this demo.
**Please describe your use case for this integration and alternatives you've tried:**
- Voice commands (as demonstrated by the demo firmware)
- Text-to-Speech
- (One-way) communication with visitors
**Additional context**
I originally commented on #599 but that appears to be a request for I2S audio _output_ while I'm requesting support for audio _input_
asetGem
(Aset Gem)
October 24, 2022, 8:24pm
3
Hi!
I’m also looking for a way to capture audio from my atom M5, and then stream it to HA in order to use it as rhasspy input.
I tried to use the custom component, but I do not get any input sound. Did you manage to set up the mic ?
tome88
(Tom)
February 25, 2023, 10:19am
4
Hi there, did you or anyone get anywhere with this? looking to do exact same thing
asetGem
(Aset Gem)
February 25, 2023, 10:48am
5
Still nothing from my side
I’m also interested in this. I’d love to use the m5stcik or m5 echo as a walkie talkie and be able to stream audio through push to talk. If anyone is able to do this, I’d love to know! Thanks
