About one month ago my hassio couldn’t start, it was some kind of issue with the file system
I managed copying most of the configuration using a linux machine, and copied to a new micro SD card
It all worked fine until one day it couldn’t write anymore
So no updates, can’t install new plugins, and if I reset it, all the new config changes are discarded
What could be the issue?
Is it possible I’ve overfilled the card or written too many times?
There is a well-known problem with fake/counterfeit versions of SanDisk SD cards coming from ebay and occasionally Amazon Marketplace vendors. Be certain you’re using a Class 10 SD card from a name brand manufacturer, preferably not SanDisk.
