Has anyone have success in creating Microsoft Services status sensor/s??
https://admin.microsoft.com/servicestatus
https://status.office.com/
I’m certain there will be much better answers than my solution, but I was able to quickly write this up for you:
sensors:
- platform: rest
resource: https://admin.microsoft.com/api/servicestatus/index
value_template: "{{ value_json.IsAllUp }}"
json_attributes:
- Services
sensors:
outlook:
value_template: '{{ states.sensor.microsoft[0].attributes["IsUp"] }}'
one_drive:
value_template: '{{ states.sensor.microsoft[1].attributes["IsUp"] }}'
You will just need to continue on with the template sensors to grab the other 5 services listed on your first link.
I’ve never really needed templates but I worked this out, in case someone knows how to turn this into a dynamic series of sensors with the above calls:
{% for state in state_attr('sensor.microsoft', 'Services') %}
{{ state.Name }} is {{ state.IsUp}}
{% endfor %}
Outlook.com is True
OneDrive is True
Microsoft To-Do is True
Skype is True
Office for the web (Consumer) is True
Microsoft Whiteboard is True
Your Phone is True
Teams (Consumer) is True
Thanks for the quick solution! This worked for me. I setup my sensors with a scan_interval of 60 and I manually changed the value of the sensors to False using Developer Tools. The value stayed False, though the actual value of the sensor from the Microsoft’s site is True.
How do I get the scan_interval to work??
