i too am having issues with this TTS - from all documentation it should be working - can nobody get it working…
this is my error i found:
ERROR (SyncWorker_11) [pycsspeechtts.pycsspeechtts] Connection Intialization failed, statuscode 401, reason: {“error”:{“code”:“401”,“message”: “Access denied due to invalid subscription key or wrong API endpoint. Make sure to provide a valid key for an active subscription and use a correct regional API endpoint for your resource.”}}
not sharing my apikey - but my configuration is almost the same as above posting except following config for endpoint and region…
