I have to ask, what is “Aristons WIfi dongle”? Is that a manufacturer dongle running the ESPHome firmware?
No it’s the manifacturer dongle running its own firmware, working with Mac-Zhou integration. If this list was only for the ESP, then I’m sorry, I misunderstood and I’ll delete my posts
Not a problem at all. Yes, this list is only for the ESPHome
custom_component
to run without a manufacturer dongle (= own ESP board).
We just wanted to show, how many A/Cs are usable without a manufacturer dongle, to make it easier for people to select an A/C that is usable with HA before buying.
PS: Just leave your posts, doesn’t matter, I’ll just take your device off the list and all is good.
in case you still search for a way to control toshiba devices - this may have you covered: GitHub - h4de5/home-assistant-toshiba_ac: Toshiba AC integration into home-assistant.io
Could you give a little more information on how you did this? I have a MrCool and it has the weird USB connector. I purchased a dongle from @sergge but I think I need to create something similar to yours. Where did you get the USB connector from? Did you have to modify it?
Did you check this thread?
We all started there, me including, some more info provided there. If you need something more, please reply in there, we can shed more light on it.
Thanks, I did check that thread and posted in there, I’m still not sure what options I have. I’m not that technical with soldering and all that, I also don’t want to mess the unit up, so I’m looking for a solution which I can add the dongle without affecting the MrCool unit.
I updated my original post with more photos and new yaml code, as there was an update to the ESPHome component in the meantime. It is all external, no modifications to the AC unit, but you need posses some soldering and electronics skill in order to create what I did. There might be some other solutions available to you if you look around. Don’t know how to help more…
Thank you, I will take a look, appreciate it!
Manufacturer: Pioneer
Model: WS012GMFI22HLD-16 wall unit.
Year: 2020
Market: US
ALSO:
Model: RB012GMFILDFHD-16 ducted unit.
Year: 2020
Market: US
This unit does NOT have the USB-style port however you can add the “Smart Kit” from Pioneer for it which does. That kit’s $99 but includes the OSK-103 stick so you could sell that to recover a bit. Or find a less expensive way to purchase. I tried to map the 4-pin port the “Smart Kit” connects to but am insufficiently skilled for that.
Looking good with both of these. These have the USB-style receptacle with the raised edges. I used @VitalyZ’s board design and a dremel to adapt the male USB plug to fit the port. Awesome!
Edited to add Market and Year info as well as 2nd ducted unit.
I’ve been messing with this esphome setup for a couple days now. I have read up on how to get my midea ac units integrated, and I have them working. But I need to be able to control the led lights on the display. I know I don’t need to do anything to control them on the iot dongle. But how do I add the custom comfiguration. I read the documentation regarding this, but it’s vague and unhelpful. Everyone assumes you just know where and how to add this stuff to the configuration yaml and they give you an “example” to go by. But do I need to rename anything or what? I’ve tried adding the example verbatim but it’s no use. I don’t need all the extra garbage in the example either just the switch to turn off the led.
I don’t think this is the wrong topic as this is the esp home component thread. That and I don’t think it’s necessary to add the or transmitter gpio either as the original dongle allowed for the led to be controlled from the app over cloud. My question was more about where I’m supposed to add the switch inclusion to. Is it added to the main config yaml or do I need to add it to each of the units separately in the yamls used by esphome?
That kinda defeats the purpose of having a community forum. The other post is more about hardware modding and such. I’m asking questions about stuff that’s been gone over in this post already. Why even make a forum post if you don’t want people to interact with it? Why isn’t it a locked thread? Why am I having this conversation with you instead of getting the information I asked for?
@wbarber69 Don’t get me wrong… but read the 1st topic of this thread please…this thread is NOT the technical support thread, this is a list for the models supported by the main thread only…
And since me nor @paddy0174 are moderators, neither one of us can lock this thread…
Manufacturer: Giatsu
Model: AROMA2R32
Modelnumber: GIA-S09AR2B-R32-I
Year: 2020
Market: PT, ES
2nd unit with higher output power:
Model: AROMA2R32
Modelnumber: GIA-S18AR2B-R32-I
Year: 2020
Market: PT, ES
Everything works fine out of the box. I bought the iot-uni-dongles from dudanov on the tindie shop.
Thanks so much for this! Works on my Pioneer WS009GMFI17HLD.The thermostat for this unit is horrible about staying reasonably close to the set temperature, and this made it so I could automate my own thermostat! Life is much better
Manufacturer: Royal Clima (Midea)
Model: Triumph Inverter
Year: 2021
Market: RU
Model ID: RCI-TN29HN (Wi-Fi Ready)
I install 2 ac. One with ESP01+Adapter and another with wemos d1 mini v3 + shifter
All work great. Thanks a lot
Manufacturer: MaxiCool (Midea)
Model: AMD-AUR-09HDI
Year: 2020
Market: EU
Installed in 3 A/C units,all with ESPHOME ESP01S+Adapter
All work great. Thanks.
