Midea A/C and ESPHome component - list of all known working models and manufacturers
Works: Senville Leto
You have to trim the sides of the MiniSplits USB port to allow proper contacts. The manufacturer uses a unique port design to block 3rd party devices. Trim the prongs and your USB will connect fine and work perfectly fine.
This list will no longer be updated, as it obviously isn’t in the stars for people to read at least a few lines in the first post. This topic was intended to be an overview for all working models, with a seperate topic to answer questions.
Thanks to all, that were able to read and act accordingly! :slight_smile:
Brand: Mirage
Model: Life 12+ ELF120T
Year: 2024
using SLWF-01Pro v2.1
Note: No outdoor temperature and humidity information, no display, no uptime, no swing step, follow_me cause no boot , all about climate work using the integrated firmware
Hey, how did you connect the USB to your Board? I have the same Model but did not figure out how to connect yet, did you solder it to CN2, WiFi? If so, how?
Greetings
Does anyone run the Pioneer WS009GMFI22HLE head unit? I have the USB dongle and using the Cloudfree module. Configured like the xtremeownage blog. Module boots and powers up but no comms with the unit.
I thought maybe I didn’t shave the USB port sufficiently so I went through and doubled checked, it appears to be good and slides it without much effort. Manufactured in 2024, not sure if they changed anything…
Cloud you share about cn4 pin?
@manticore1 Please zoom in on the third picture in my post, you can see the definition of each pin.
I haven’t received my unit yet, did you have to buy the white plug connector to usb A cable (black cable) or is it included?
Hello
I have Midea MCA4U-18HRFNX(GA)
Is there any possibility to integrate it with Home Assistant using esphome.
There is no USB port since it’s cassette AC
There is CN40 port (smart port)
and XYE port inside
This unit don’t have wifi
Here some photo of main board
midea ac - Google Drive
Can you tell me why midea_ac.follow_me from Home Assistant is not being transmitted via ESP to the air conditioner?? Do I need an IR sensor for this?
Read the first post mate. More importantly, read why it was closed.
This thread was created to list known working models, not to ask generic questions about issues. There’s a linked thread in the first post (with plenty of people asking your same question there) if you bother to read.
Hi!
anyone has experience with the CN16 Wifi port?
Thanks!
Brand: Electra
Model: CoolAir
Model IDs: 21/WMD18FXE, 10/WMD09FXE, 14WMD12FXE
Year: 2019?
Market: IL
Everything works except the IR transmitter, so the display toggle and swing step functions are not working yet.
Hi, within the code, which platform did you achieve a connection with (Midea, Haier, etc.)? I have a Mirage V32 working with the original Mirage Wi-Fi dongle, but I haven’t been able to get it to work (not even connect to the device) with an ESP32 C3 Mini (which I built) or now with the SLWF01Pro.
Nothing for mitsubishi ?
the official module is this MAC-557IF-E
