Midea AC - Min Temperature not being honoured
Possibly an odd question - but I’ve got my Bosch a/c units hooked up to Home Assistant, by using the ESP Home midea component.
It all works great but my units go down to 16C, so I changed the min_temperature to 16.
The oddness comes because the UI keeps resetting the temp to 17C, on the web page of the dongle running ESP Home, and thus Home Assistant.
The AC stays at 16C, unless I turn it off and on again.
It’s not huge, but I am curious if anybody else has seen this and knows what’s going on.
Thanks in advance!
Can I bump this, in the hopes of finding someone who has had a similar problem?
Same here. When you set the temperature to 16, it is set on the device, but returns to 17 in Home Assistant.
I found the solution for me with the SLWF-01pro (v.2.1) device.
It should also be possible to flash via Wifi and you can skip to install the driver, but for me that didn´t work.
Anyone else have luck with this? Seems the links to the drivers are now broken.
