My HASS instalation:
I’m trying to use the “Midea Aircon” integration with HACS but I still get a “timeout” error.
The Wifi module is “OSK-103”
configuration:
climate:
- platform: midea
app_key: 3742e9e5842d4ad59c2db887e12449f9
username: '[email protected]'
password: !secret midea_password
Here is my log:
Update for climate.midea_18691697883668 fails
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 445, in _make_request
six.raise_from(e, None)
File "<string>", line 3, in raise_from
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 440, in _make_request
httplib_response = conn.getresponse()
File "/usr/local/lib/python3.8/http/client.py", line 1344, in getresponse
response.begin()
File "/usr/local/lib/python3.8/http/client.py", line 307, in begin
version, status, reason = self._read_status()
File "/usr/local/lib/python3.8/http/client.py", line 268, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
File "/usr/local/lib/python3.8/socket.py", line 669, in readinto
return self._sock.recv_into(b)
File "/usr/local/lib/python3.8/ssl.py", line 1241, in recv_into
return self.read(nbytes, buffer)
File "/usr/local/lib/python3.8/ssl.py", line 1099, in read
return self._sslobj.read(len, buffer)
socket.timeout: The read operation timed out
File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 755, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.8/site-packages/urllib3/util/retry.py", line 532, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.8/site-packages/urllib3/packages/six.py", line 770, in reraise
raise value
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 699, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 447, in _make_request
self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 336, in _raise_timeout
raise ReadTimeoutError(
urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='mapp.appsmb.com', port=443): Read timed out. (read timeout=9)
I used curl to check the connection and it’s OK
~ $ curl https://mapp.appsmb.com
{"errorCode":"0","msg":"基类controller","result":"com.midea.smart.basehttp.controller.BaseController"}
Has anyone had the same problem?
Regards
M@rek
