I would like to request your help in a Midea based Bosch climate …
I have 4 pcs. Bosch Climate 3000i (3,5kW) where I have successfully created and connect to HA with Wemos D1 Mini.
It is a small issue with the Bosch Climate 5000 RAC (5,4kW) … Previously the Bosch dongle are worked on this type also, but unfortunately not working with Wemos D1 Mini configuration. No RX receiving from the climate board …
I have try to swap the tx/rx as recommend many times above, but doesn’t help unfortunately.
Can i use a ESP32 Dev board and use the RX/TX pins directly to the Midea controller?
I dont have the USB cable. Or do i have to use a FTDI type converter?
@glenman I advice to use a level shifter, as the Midea works on 5V, and the ESP32 on 3.3V.
This could fry the esp, or worse the Midea…better be safe then sorrow
And it is NOT an USB connector; it is a serial connector (which looks like a USB):
And how you connect it is up to you; I use the header plug:
Some others had issues with the usb-look-alike and ended up soldering it straight on the pcb
Can you outline the steps you took to get a sensor from homeassistant working for follow_me? The current temp for the AC is still reading off the onboard sensor. This is what I have in my yaml config.
The S3 DIP switch bank is the small red rectangular box near the bottom left corner of your circuit board picture, and is currently set to 0-0-0-0 which per the description table is the master address. If you want to set a different address, use a ball-point pen or small screwdriver to slide S3 switches #1-3 per the table. Don’t touch switch #4, as it is reserved for future use and should remain set to zero…
I have an ActronAir AC which uses the same IR signals as a Midea AC. So I’m assuming it uses a lot of Midea parts. However the board looks a little different to what others have posted.
Anyone had to buy the usb intermediate board/plug for their unit? My Bryant minisplit doesn’t have the USB Port but it is an optional addon. It’s a 619P*B unit and the board looks like this
Have you had any luck getting any more data from the stream? I have a servile and have connected through the xye terminals but only get limited data.I would love to get power consumption and compressor frequency so I can figure out my COP.
i keep having the wifi error by installing the esp01 for the first time. Trying everything.
I read al the manuals but nothing helps. I used esphome on my home assistant dashboard and plug the usb adapter into my win pc. If i do this with an D1 mini than it work always. But with the esp-01 and adaptor not ??
Original post: I am currently also working to open the device. How did you manage to open the fairing? With brute force or are there some tricks? I started from the top and want to remove the backside first with tools from ifixit. But these clamps seem to be pretty tough to open.
I managed to open the case by dragging the back with quite some force. After that things were easy. The front is hold in place by some more screws. After that I could access the USB port. No need to disassemble the front down and top cover to the mainboard (at least for my device).
One note from my side: after the custom USB dongle was installed the remote does not work anymore. I seems that it directly communicates with the original USB dongle. That’s a bit o a pity since it is well-designed but a tolerable sacrifice to get full HA integration.
@helgew , @aceindy , did you find anything more about the KSACN0701AAA?
So much (contradictionary) info this thread, I am totally lost. I have a similar thermostat (KSACN1001AAA) with a full blown Carrier Performance 40MBABQ36XA3. Barely anything can be found on the internet.
However, the thermostat is connected via two wires “HA” and “HB” to the air handler (indoor unit). The manual vaguely mentions “RS485”.
Questions:
Can someone clarify that HA/HB interface is actually RS-485, over which modbus is ran?
Can I attach an ESP32 with RS485 adapter in parallel to this?
