I have a Mitsui mtxi12hp24. What’s currently the best solution for local control via Home Assistant? In particular regarding the dongle.
One concern is that I don’t want a random user to be able to easily tamper with the module. If there’s no case, it just looks horrible.
Someone created a 3d printed case, but I’d like to just buy a complete package. I can do 30 minutes of assembly, but I really prefer not to, because such projects can suck up time for all kinds of reasons including supply chain risk.
There’s a guy in Ukraine which developed a module that can be inserted in the USB port. Is that different? I don’t think the Ukrainian product has a case either.
A solution where a random user can see a PCB generally would lead to questions, so I want to avoid that.
Thanks a lot everyone for the non-trivial effort you have done so far.
maybe someone has already tried it. How to replace the current temperature? So the AC (midea / rotenso) is reading temperature from the unit integrated sensor - but readings sometimes are so bad that I need a way to override them.
Yeah it looks the same as what I got. My AC doesn’t have that USB to PCB cable/connector. Do these dongles ship with the cable or assume you already have it in your AC?
Edit: is it called usb2header cable?
Edit2: re/read this thread. It’s called female usb to jst apparently.
Hi Jakob,
it seems I have a similir heat pump branded hyundai but based on Midea. I’m struggeling to connect to the Modbus interface. For debugging I’m using a RS458 → ETH converter.
If I conect this to the H1, H2 and ground terminals on the external controller I can’t read any modbus registers. If I connect to H1/H2 in the Heat Pump I receive some garbage but no Modbus communication. Do you know if this Modbus feature needs to be enabled somehow in the controller?
I purchased a SLWF-01pro from smartlight.me and connected it to my Home Assistant as documented by them. It shows up in my Integrations under ESPHome and properly identifies itself as a climate entity and outdoor thermometer. All good so far.
However, it doesn’t show up on the actual ESPHome panel as something I can update or modify.
What’s the process for getting ESPHome to “adopt” it so it can manage it? Or should I, even?
I’ve also bought an SLWF-01pro from smartlight.me.
I want to reflash the esp12f chip but I don’t know how to do.
I have connected to ESPHome in home assistant but it’s undetected. Same things on windows. On the board there is two button (RES and FLH).
I’ve tried a lot of time but nothing happen
