Midea/clivet/italtherm app iletcomfort integration
Hi all, I’m would like to connect my italtherm hydrablock C in home assistant. It is connected in the app “iLetComfort” which is in cloud. The connection is made using WiFi (standard onboard on italtherm hydrablock).
I searched online but I didn’t find anything.
Do you know if it is possible?
I have a heat pump from Rossato that I control via the iLetComfort app.
Its WiFi controller appears to be compatible with the Midea models. I have installed the Midea component in Home Assistant following the instructions at GitHub - georgezhao2010/midea_ac_lan: Auto-configure and then control your Midea M-Smart devices (Air conditioner, Fan, Water heater, Washer, etc) via local area network.. It recognizes the WiFi controller and it confirms that my model is supported, but it asks to log into the Midea account to download the device information:
I don’t have a Midea account as I don’t have a Midea device and I cannot register it.
I also contacted the iLetComfort support team to ask for a list of compatible controllers and their brands, but I did not get any response.
Hi! I managed to add the WiFi controller to the Midea platform and the Midea integration in Home Assistant recognized the controller correctly.
  1. Download the Midea Smarthome app and create an account
  2. Open the app and add the heat pump WiFi controller. Even if it is not a Midea device it should be compatible, if you can control it via iLetComfort). I picked the model KJRH-120F/K and it recognized it instantly.
  3. Install the Midea integration following the instructions at GitHub - georgezhao2010/midea_ac_lan: Auto-configure and then control your Midea M-Smart devices (Air conditioner, Fan, Water heater, Washer, etc) via local area network.
  4. Add a new device in Home Assistant and search for the Midea integration.
  5. Follow the steps to discover the controller, and log into your Midea account to configure your device.
UPDATE FEBRUARY 2025:
I managed to follow the guide provided by @sutnevju, the only thing that must be changed is to use this integration, which is updated and works. You can either use the old Midea Air app or the new SmartHome app, it works with both. Lookup the device name, don’t follow the generic procedure. For my “System Air” panel, I searched for KJRH-120F/K like in the picture above and was able to correctly configure it.
I recently bought an ITS heatpump, however the Midea app failed to detect it.
I ended up reverse-engineering the protocol…
CLI tool/client: GitHub - tgenov/iletcomfort-cli: Reverse-engineered Python client for ITS/BTRI heat pumps (Midea 0xC3) controlled via the iLetComfort app · GitHub
HACS plugin/integration: GitHub - tgenov/ha-iletcomfort: Home Assistant custom integration for ITS/BTRI iLetComfort heat pumps · GitHub
