Hi All,
Any idea about how to Integrate MIDEA M7 Pro Robot Vacuum with Home Assistant
Did you find something? I have it integrated through broadlink
Interested in how you did this, does it just give you the option to trigger a clean or can you read the statuses?
Just activate cleaning and send to base! I can’t know the status via broadlink
Any idea how to integrate?
broadlink only
I did it via google sdk. The vacuum can integrate in google. So I use a script to send a voice command to google.
I did it via yandex api which in turn is connected to midea api but it’s not ideal setup.
I suppose there’s much more use if we have local midea api so you will be able to block your vaccum in firewall and restrict it only to your local network. I’ve already done that for my tuya, xiaomi devices and had no regrets. So, truly want a capability of local control without internet
Finally, someone made an integration that supports Midea vacuums and other Midea products. Here’s the link: GitHub - sususweet/midea_auto_cloud: Control Midea devices via Cloud from Home Assistant
I tested it with my Midea i5c and it works very well — quite complete.
Thanks very much sususweet!!
