Indeed! The battery is not available. But the connection to the devices is way better then before somehow. Before sometimes the whole sensor would be unavailable for a couple hours, not sure of the reason.
Yup, since Passive BLE listens for the broadcasts from the sensor. As a side benefit, this should save battery since the device is not polled actively.
Another solution is to build a small esp board running this
Thanks - this worked for me too! BUT⌠now my Bluetooth device tracker has stopped working (the built in integration) because this new custom integration has taken over access to the Bluetooth adapter.
Anyone else had this problem?
Does anyone know if there are plans to fix the underlying fault with the built in miflora integration?
MiFlora is not broadcatsing battery level anymore, but it sends battery level in response when requested. Does anyone knows how to request battery level or any active MiFlora integration?
Just wanted to know if some of you experience the same?
At some point everything stopped working. No more connection to the sensors via the âBluetooth Low Energy Monitorâ. I could not figure out why.
Then we get the new update, giving BT integration a major update. So one by one the plant sensors started appearing as a new device âFlower Careâ. I have 4 but that took several days before all arrived. Now all are in but some are not responding
The new HA BLE integrations are using active scanning right now. This may change in the future, as bleak has been adjusted to allow passive scanning a couple of days ago.
