Miflora Issue with BLE?
I suspect a problem on my setup with Miflora components, getting:
connect error: Transport endpoint is not connected (107)
all over the log…
I am not 100% it’s that component but would love to know if anyone else saw this and how it can be handled?
Do you use the BT device to conenct to something else as well? Also check the permissions for the HA user
Thanks for looking into this @moskovskiy82
I have bluetooth_tracker setup (but I don’t relay on it for much if that’s a problem) - should I remove or something?
And what do you mean check HA user permission? Where? how? (I am using the all in one setup for HA)
That is the problem. Mi Flower needs to get the BT all for itself. No other connections possible.
