Hi All, I thought that I would share some info that I have come across to get MiFlora working again. My story starts one day when I decide that it was time to completely upgrade my Homeassistant, because I could no longer upgrade due to python. My choice of install was Hassbian. Once installed this brought my Homeassistant version to 99.3. Not to bore you with all the install details and get to the topic at hand, I was having trouble with the MiFlora sensors. Sometimes they would work and other times they would not, not like my old installation of Homeassistant which always worked, so I start to do my research.
I learned that performing a âsudo hciconfig hci0 downâ, followed by a âsudo hciconfig hci0 upâ would fix things temporarily. I thought about just running a bash script to automatically do this every hour or so, but I decided not to, in favor of something else. Can you say ESPHome, I can. I had a esp32 just laying around, begging me to use it. So, I setup ESPHome as the MiFlora BLE Sensor:
https://esphome.io/components/sensor/xiaomi_miflora.html
I setup everything, and my sensor was live, but I wasnât getting any data, why me? After, doing a bunch more research I found that the ESPHome sensor does not work with all version of the MiFlora firmware. I was on version 2.4.2, and when I looked in the MiHome app I saw that I could upgrade to version 3.1.9. Done deal, I hit upgrade and hope for the best. With the upgrade completed, and 5mins wait time I was getting data in the ESPHome sensors, yippy. Another project to put to bed, until I realized that all the sensors were getting data except the battery sensor. I though maybe the MiFlora only sends out battery info every so often, so I waited. Two days later still no battery info, do I leave it or find a solution? Solution time here I come. I thought to myself, hey maybe with the update of the MiFlora maybe the Homeassistant component would work now. I setup the original MiFlora component and waited, and waited and waited. I received no data at all now even after turning the bluetooth off then on again, damn why did I upgrade that MiFlora!
Well, when you think my story is over it is just ready to begin. I performed a âsudo hcitool lescanâ to see if my MiFlora would show up, and it would not and sometimes it would seem like something would crash because I could not exit out of the screen. Well back to google. If I performed a âsudo systemctl status bluetoothâ I would end up with this:
â bluetooth.service - Bluetooth service
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset
Active: active (running) since Sun 2019-10-13 17:35:20 BST; 22min ago
Docs: man:bluetoothd(8)
Main PID: 464 (bluetoothd)
Status: âRunningâ
Tasks: 1 (limit: 2200)
Memory: 2.1M
CGroup: /system.slice/bluetooth.service
ââ464 /usr/lib/bluetooth/bluetoothd
Oct 13 17:35:20 hassbian systemd[1]: Starting Bluetooth serviceâŚ
Oct 13 17:35:20 hassbian bluetoothd[464]: Bluetooth daemon 5.50
Oct 13 17:35:20 hassbian systemd[1]: Started Bluetooth service.
Oct 13 17:35:20 hassbian bluetoothd[464]: Starting SDP server
Oct 13 17:35:20 hassbian bluetoothd[464]: Bluetooth management interface 1.14 in
Oct 13 17:35:20 hassbian bluetoothd[464]: Sap driver initialization failed.
Oct 13 17:35:20 hassbian bluetoothd[464]: sap-server: Operation not permitted (1
Oct 13 17:35:20 hassbian bluetoothd[464]: Failed to set privacy: Rejected (0x0b)
Hmm, Sap driver initialization failed that canât be good. All this for a damn plant! Ok, how do I fix that, where are we going now, hello Google. Googles reply, " The solution you are looking for is this:"
Open file:
/etc/systemd/system/bluetooth.target.wants/bluetooth.service
And change this:
ExecStart=/usr/lib/bluetooth/bluetoothd
To this:
ExecStart=/usr/lib/bluetooth/bluetoothd --noplugin=sap
Reload the systemd:
sudo systemctl daemon-reload
And, restart bluetooth:
sudo service bluetooth restart
Ok, here is the moment of true, lets run this again âsudo systemctl status bluetoothâ, boom:
Loaded: loaded (/lib/systemd/system/bluetooth.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2019-10-13 19:14:27 BST; 27s ago
Main PID: 7934 (bluetoothd)
Status: âRunningâ
Memory: 608.0K
ââ7934 /usr/lib/bluetooth/bluetoothd --noplugin=sap
Oct 13 19:14:27 hassbian systemd[1]: Starting Bluetooth serviceâŚ
Oct 13 19:14:27 hassbian bluetoothd[7934]: Bluetooth daemon 5.50
Oct 13 19:14:27 hassbian systemd[1]: Started Bluetooth service.
Oct 13 19:14:27 hassbian bluetoothd[7934]: Starting SDP server
Oct 13 19:14:27 hassbian bluetoothd[7934]: Excluding (cli) sap
Oct 13 19:14:27 hassbian bluetoothd[7934]: Bluetooth management interface 1.14 initialized
Hip Hip hurray, so, did this fix my original issue? Lets run âsudo hcitool lescanâ and see if it sees my MiFlora. Ta Dahhh, it does, and when I look at the the original MiFlora component in Homeassistant all of the sensors have been populated, hello battery sensor, how I have missed you.
Well, I am happily back up and running, I am not saying this is the end all fix, but for the time being it has me up and running, and I thought I would share and publish this info, all in one place to help others, so Happy Green Thumbing.
