I’ve successfully put the MiFlora sensors into HA before through the core HA component. However, due to the position of the sensors and my RPi, I decided to use an ESP32 as a BLE hub for better connectivity.
I’ve followed the instructions and everything appears to be working. The sensor node is online and it is detecting the MAC address of the MiFlora sensor. It is not however showing up in Home Assistant.
This is my yaml:
esphome:
platform: ESP32
board: esp-wrover-kit
wifi:
ssid: "**********"
password: "***********"
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
esp32_ble_tracker:
scan_interval: 300s
- platform: xiaomi_miflora
mac_address: C4:7C:8D:67:C0:8B
temperature:
name: "Xiaomi MiFlora Temperature"
moisture:
name: "Xiaomi MiFlora Moisture"
illuminance:
name: "Xiaomi MiFlora Illuminance"
conductivity:
name: "Xiaomi MiFlora Soil Conductivity"
battery_level:
name: "Xiaomi MiFlora Battery Level"
This is the logs once all uploaded:
[16:01:30][I][application:097]: esphome-core version 1.12.2 compiled on Apr 24 2019, 15:59:09
[16:01:30][C][wifi:371]: WiFi:
[16:01:30][C][wifi:253]: SSID: [redacted]
[16:01:30][C][wifi:254]: IP Address: 192.168.1.49
[16:01:30][C][wifi:256]: BSSID: [redacted]
[16:01:30][C][wifi:257]: Hostname: 'blehubtrack'
[16:01:30][C][wifi:261]: Signal strength: -54 dB ▂▄▆█
[16:01:30][C][wifi:262]: Channel: 6
[16:01:30][C][wifi:263]: Subnet: 255.255.255.0
[16:01:30][C][wifi:264]: Gateway: 192.168.1.1
[16:01:30][C][wifi:265]: DNS1: 192.168.1.1
[16:01:30][C][wifi:266]: DNS2: 0.0.0.0
[16:01:30][C][logger:142]: Logger:
[16:01:30][C][logger:143]: Level: DEBUG
[16:01:30][C][logger:144]: Log Baud Rate: 115200
[16:01:30][C][logger:145]: Hardware UART: UART0
[16:01:30][C][esp32_ble_tracker:703]: BLE Tracker:
[16:01:30][C][esp32_ble_tracker:704]: Scan Interval: 300 s
[16:01:30][C][esp32_ble_tracker:712]: Xiaomi 0000C47C8D67C08B
[16:01:30][C][esp32_ble_tracker:713]: Temperature 'Xiaomi MiFlora Temperature'
[16:01:30][C][esp32_ble_tracker:713]: Unit of Measurement: '°C'
[16:01:30][C][esp32_ble_tracker:713]: Accuracy Decimals: 1
[16:01:30][C][esp32_ble_tracker:715]: Moisture 'Xiaomi MiFlora Moisture'
[16:01:30][C][esp32_ble_tracker:715]: Unit of Measurement: '%'
[16:01:30][C][esp32_ble_tracker:715]: Accuracy Decimals: 0
[16:01:30][C][esp32_ble_tracker:715]: Icon: 'mdi:water-percent'
[16:01:30][C][esp32_ble_tracker:716]: Illuminance 'Xiaomi MiFlora Illuminance'
[16:01:30][C][esp32_ble_tracker:716]: Unit of Measurement: 'lx'
[16:01:30][C][esp32_ble_tracker:716]: Accuracy Decimals: 0
[16:01:30][C][esp32_ble_tracker:716]: Icon: 'mdi:brightness-5'
[16:01:30][C][esp32_ble_tracker:717]: Conductivity 'Xiaomi MiFlora Soil Conductivity'
[16:01:30][C][esp32_ble_tracker:717]: Unit of Measurement: 'µS/cm'
[16:01:30][C][esp32_ble_tracker:717]: Accuracy Decimals: 0
[16:01:30][C][esp32_ble_tracker:717]: Icon: 'mdi:flower'
[16:01:30][C][esp32_ble_tracker:718]: Battery Level 'Xiaomi MiFlora Battery Level'
[16:01:30][C][esp32_ble_tracker:718]: Unit of Measurement: '%'
[16:01:30][C][esp32_ble_tracker:718]: Accuracy Decimals: 0
[16:01:30][C][esp32_ble_tracker:718]: Icon: 'mdi:battery'
[16:01:30][C][api:101]: API Server:
[16:01:30][C][api:102]: Address: blehubtrack.local:6053
[16:01:30][C][ota:127]: Over-The-Air Updates:
[16:01:30][C][ota:128]: Address: blehubtrack.local:3232
[16:06:25][D][esp32_ble_tracker:431]: Found device C4:7C:8D:67:C0:8B RSSI=-44
[16:06:25][D][esp32_ble_tracker:452]: Address Type: PUBLIC
Now, one thing I have noticed from the ESPHome guides. When discovering devices, it has never displayed this:
Xiaomi MiFlora 94:2B:FF:5C:91:61 Got temperature=23.4°C
Which as per this page, it should. Is it a case that it can see the device, but isn’t recognising it as a MiFlora device? Running sudo hcitool lescan
shows C4:7C:8D:67:C0:8B Flower care
when run from my Pi.
