I have a raspberry pi 3 running HA. Also i have a xiaomi plant sensor.
Yesterday for a period of time, i linked the miflora plant sensor wih BLE of raspberry using bluetoothctl and i watched values in HA state website. After that i restarted the raspberry.
Today i dunno why, when i see the values of miflora sensors in state website of HA says “unknown”.
If i see the bluetoothctl in the raspberry i see this:
2017-05-12 13:16:25 DEBUG (Thread-7) [homeassistant.components.sensor.miflora] Polling data for Planta_Terraza
Moisture
2017-05-12 13:16:25 DEBUG (Thread-7) [miflora.miflora_poller] Enter read_ble (<Thread(Thread-7, started daemon
1917842528)>)
2017-05-12 13:16:25 DEBUG (Thread-7) [miflora.miflora_poller] Created lock in thread <Thread(Thread-7, started
daemon 1917842528)>
2017-05-12 13:16:25 DEBUG (Thread-7) [miflora.miflora_poller] Running gatttool with a timeout of 20
2017-05-12 13:16:31 WARNING (MainThread) [homeassistant.components.cover.mqtt] Payload is not True, False, or
integer (0-100): event,subirpers
2017-05-12 13:16:34 DEBUG (Thread-7) [miflora.miflora_poller] Finished gatttool
2017-05-12 13:16:34 DEBUG (Thread-7) [miflora.miflora_poller] Released lock in thread <Thread(Thread-7, starte
d daemon 1917842528)>
2017-05-12 13:16:34 DEBUG (Thread-7) [miflora.miflora_poller] Got from gatttool
2017-05-12 13:16:34 DEBUG (Thread-7) [miflora.miflora_poller] Waiting for 10 seconds before retrying
2017-05-12 13:16:35 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.planta_terraza_moisture is taking over
10 seconds
2017-05-12 13:16:44 DEBUG (Thread-7) [miflora.miflora_poller] Created lock in thread <Thread(Thread-7, started daemon 1917842528
2017-05-12 13:16:44 DEBUG (Thread-7) [miflora.miflora_poller] Running gatttool with a timeout of 20
2017-05-12 13:16:49 DEBUG (Thread-7) [miflora.miflora_poller] Finished gatttool
2017-05-12 13:16:49 DEBUG (Thread-7) [miflora.miflora_poller] Released lock in thread <Thread(Thread-7, started daemon 191784252
8)>
2017-05-12 13:16:49 DEBUG (Thread-7) [miflora.miflora_poller] Got from gatttool
2017-05-12 13:16:49 DEBUG (Thread-7) [miflora.miflora_poller] Waiting for 20 seconds before retrying
2017-05-12 13:16:49 DEBUG (Thread-7) [miflora.miflora_poller] Created lock in thread <Thread(Thread-7, started daemon 1917842528
2017-05-12 13:16:49 DEBUG (Thread-7) [miflora.miflora_poller] Running gatttool with a timeout of 20
2017-05-12 13:16:56 WARNING (MainThread) [homeassistant.components.sensor] Updating miflora sensor took longer than the schedule
d update interval 0:00:30
2017-05-12 13:17:02 DEBUG (Thread-7) [miflora.miflora_poller] Finished gatttool
2017-05-12 13:17:02 DEBUG (Thread-7) [miflora.miflora_poller] Released lock in thread <Thread(Thread-7, started daemon 191784252
8)>
2017-05-12 13:17:02 DEBUG (Thread-7) [miflora.miflora_poller] Got from gatttool
2017-05-12 13:17:02 DEBUG (Thread-7) [miflora.miflora_poller] Waiting for 20 seconds before retrying
2017-05-12 13:17:02 DEBUG (Thread-7) [miflora.miflora_poller] Exit read_ble, no data (<Thread(Thread-7, started daemon 191784252
8)>)
2017-05-12 13:17:02 INFO (Thread-7) [homeassistant.components.sensor.miflora] Polling error [Errno Could not read data from Mi F
lora sensor %s] C4:7C:XX:XX:XX:XX
2017-05-12 13:17:02 DEBUG (Thread-5) [homeassistant.components.sensor.miflora] Polling data for Planta_Terraza Light intensity
2017-05-12 13:17:02 DEBUG (Thread-5) [miflora.miflora_poller] Using cache (0:15:00.006369 < 0:20:00)
2017-05-12 13:17:02 INFO (Thread-5) [homeassistant.components.sensor.miflora] Polling error [Errno Could not read data from Mi F
2017-05-12 13:17:02 DEBUG (Thread-3) [homeassistant.components.sensor.miflora] Polling data for Planta_Terraza Conductivity
2017-05-12 13:17:02 DEBUG (Thread-3) [miflora.miflora_poller] Using cache (0:15:00.010528 < 0:20:00)
2017-05-12 13:17:02 INFO (Thread-3) [homeassistant.components.sensor.miflora] Polling error [Errno Could not read data from Mi F
2017-05-12 13:17:02 DEBUG (Thread-10) [homeassistant.components.sensor.miflora] Polling data for Planta_Terraza Temperature
2017-05-12 13:17:02 DEBUG (Thread-10) [miflora.miflora_poller] Using cache (0:15:00.017253 < 0:20:00)
2017-05-12 13:17:02 INFO (Thread-10) [homeassistant.components.sensor.miflora] Polling error [Errno Could not read data from Mi
Flora sensor %s] C4:7C:XX:XX:XX:XX
2017-05-12 13:17:02 DEBUG (Thread-8) [homeassistant.components.sensor.miflora] Polling data for Planta_Terraza Battery
2017-05-12 13:17:02 DEBUG (Thread-8) [miflora.miflora_poller] Enter read_ble (<Thread(Thread-8, started daemon 1907356768)>)
2017-05-12 13:17:02 DEBUG (Thread-8) [miflora.miflora_poller] Created lock in thread <Thread(Thread-8, started daemon 1907356768
2017-05-12 13:17:02 DEBUG (Thread-8) [miflora.miflora_poller] Running gatttool with a timeout of 20
2017-05-12 13:17:10 DEBUG (Thread-8) [miflora.miflora_poller] Finished gatttool
2017-05-12 13:17:10 DEBUG (Thread-8) [miflora.miflora_poller] Released lock in thread <Thread(Thread-8, started daemon 190735676
8)>
2017-05-12 13:17:10 DEBUG (Thread-8) [miflora.miflora_poller] Got from gatttool
2017-05-12 13:17:10 DEBUG (Thread-8) [miflora.miflora_poller] Waiting for 10 seconds before retrying
2017-05-12 13:17:12 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.planta_terraza_battery is taking over 1
0 seconds
2017-05-12 13:17:20 DEBUG (Thread-8) [miflora.miflora_poller] Created lock in thread <Thread(Thread-8, started daemon 1907356768
2017-05-12 13:17:20 DEBUG (Thread-8) [miflora.miflora_poller] Running gatttool with a timeout of 20
2017-05-12 13:17:27 WARNING (MainThread) [homeassistant.components.sensor] Updating miflora sensor took longer than the schedule
2017-05-12 13:17:40 DEBUG (Thread-8) [miflora.miflora_poller] Killed hanging gatttool
2017-05-12 13:17:40 DEBUG (Thread-8) [miflora.miflora_poller] Released lock in thread <Thread(Thread-8, started daemon 190735676
8)>
2017-05-12 13:17:40 DEBUG (Thread-8) [miflora.miflora_poller] Got from gatttool
2017-05-12 13:17:40 DEBUG (Thread-8) [miflora.miflora_poller] Waiting for 20 seconds before retrying
2017-05-12 13:17:40 DEBUG (Thread-8) [miflora.miflora_poller] Created lock in thread <Thread(Thread-8, started daemon 1907356768
2017-05-12 13:17:40 DEBUG (Thread-8) [miflora.miflora_poller] Running gatttool with a timeout of 20
2017-05-12 13:17:40 DEBUG (Thread-8) [miflora.miflora_poller] Finished gatttool
8)>
2017-05-12 13:17:40 DEBUG (Thread-8) [miflora.miflora_poller] Exit read_ble, no data (<Thread(Thread-8, started daemon 190735676
8)>)
2017-05-12 13:17:40 DEBUG (Thread-8) [homeassistant.components.sensor.miflora] Planta_Terraza Battery = 0
2017-05-12 13:17:40 DEBUG (Thread-8) [homeassistant.components.sensor.miflora] Data collected: [0]
2017-05-12 13:17:40 DEBUG (Thread-8) [homeassistant.components.sensor.miflora] Not yet enough data for median calculation
2017-05-12 13:17:58 DEBUG (Thread-1) [homeassistant.components.sensor.miflora] Polling data for Planta_Terraza Moisture
2017-05-12 13:17:58 DEBUG (Thread-1) [miflora.miflora_poller] Using cache (0:15:56.443086 < 0:20:00)
2017-05-12 13:17:58 INFO (Thread-1) [homeassistant.components.sensor.miflora] Polling error [Errno Could not read data from Mi F
2017-05-12 13:17:58 DEBUG (Thread-4) [homeassistant.components.sensor.miflora] Polling data for Planta_Terraza Light intensity
2017-05-12 13:17:58 DEBUG (Thread-4) [miflora.miflora_poller] Using cache (0:15:56.451180 < 0:20:00)
2017-05-12 13:17:58 INFO (Thread-4) [homeassistant.components.sensor.miflora] Polling error [Errno Could not read data from Mi F
2017-05-12 13:17:58 DEBUG (Thread-6) [homeassistant.components.sensor.miflora] Polling data for Planta_Terraza Conductivity
2017-05-12 13:17:58 DEBUG (Thread-6) [miflora.miflora_poller] Using cache (0:15:56.461081 < 0:20:00)
2017-05-12 13:17:58 INFO (Thread-6) [homeassistant.components.sensor.miflora] Polling error [Errno Could not read data from Mi F
2017-05-12 13:17:58 DEBUG (Thread-9) [homeassistant.components.sensor.miflora] Polling data for Planta_Terraza Temperature
2017-05-12 13:17:58 DEBUG (Thread-9) [miflora.miflora_poller] Using cache (0:15:56.467504 < 0:20:00)
2017-05-12 13:17:58 INFO (Thread-9) [homeassistant.components.sensor.miflora] Polling error [Errno Could not read data from Mi F
2017-05-12 13:17:58 DEBUG (Thread-12) [homeassistant.components.sensor.miflora] Polling data for Planta_Terraza Battery
2017-05-12 13:17:58 DEBUG (Thread-12) [miflora.miflora_poller] Enter read_ble (<Thread(Thread-12, started daemon 1873802336)>)
2017-05-12 13:17:58 DEBUG (Thread-12) [miflora.miflora_poller] Created lock in thread <Thread(Thread-12, started daemon 18738023
36)>
2017-05-12 13:17:58 DEBUG (Thread-12) [miflora.miflora_poller] Running gatttool with a timeout of 20
2017-05-12 13:18:02 DEBUG (Thread-12) [miflora.miflora_poller] Finished gatttool
2017-05-12 13:18:02 DEBUG (Thread-12) [miflora.miflora_poller] Released lock in thread <Thread(Thread-12, started daemon 1873802
336)>
2017-05-12 13:18:02 DEBUG (Thread-12) [miflora.miflora_poller] Got from gatttool
2017-05-12 13:18:02 DEBUG (Thread-12) [miflora.miflora_poller] Waiting for 10 seconds before retrying
2017-05-12 13:18:08 WARNING (MainThread) [homeassistant.helpers.entity] Update of sensor.planta_terraza_battery is taking over 1
0 seconds
2017-05-12 13:18:12 DEBUG (Thread-12) [miflora.miflora_poller] Created lock in thread <Thread(Thread-12, started daemon 18738023
36)>
2017-05-12 13:18:12 DEBUG (Thread-12) [miflora.miflora_poller] Running gatttool with a timeout of 20
2017-05-12 13:18:26 DEBUG (Thread-12) [miflora.miflora_poller] Finished gatttool
2017-05-12 13:18:26 DEBUG (Thread-12) [miflora.miflora_poller] Released lock in thread <Thread(Thread-12, started daemon 1873802
336)>
2017-05-12 13:18:26 DEBUG (Thread-12) [miflora.miflora_poller] Got from gatttool
2017-05-12 13:18:26 DEBUG (Thread-12) [miflora.miflora_poller] Waiting for 20 seconds before retrying
2017-05-12 13:18:26 DEBUG (Thread-12) [miflora.miflora_poller] Created lock in thread <Thread(Thread-12, started daemon 18738023
36)>
2017-05-12 13:18:26 DEBUG (Thread-12) [miflora.miflora_poller] Running gatttool with a timeout of 20
2017-05-12 13:18:29 WARNING (MainThread) [homeassistant.components.sensor] Updating miflora sensor took longer than the schedule
2017-05-12 13:18:33 DEBUG (Thread-12) [miflora.miflora_poller] Finished gatttool
2017-05-12 13:18:33 DEBUG (Thread-12) [miflora.miflora_poller] Released lock in thread <Thread(Thread-12, started daemon 1873802
336)>
2017-05-12 13:18:33 DEBUG (Thread-12) [miflora.miflora_poller] Got from gatttool
2017-05-12 13:18:33 DEBUG (Thread-12) [miflora.miflora_poller] Waiting for 20 seconds before retrying
2017-05-12 13:18:33 DEBUG (Thread-12) [miflora.miflora_poller] Exit read_ble, no data (<Thread(Thread-12, started daemon 1873802
336)>)
2017-05-12 13:18:33 DEBUG (Thread-12) [homeassistant.components.sensor.miflora] Planta_Terraza Battery = 0
2017-05-12 13:18:33 DEBUG (Thread-12) [homeassistant.components.sensor.miflora] Data collected: [0, 0]
2017-05-12 13:18:33 DEBUG (Thread-12) [homeassistant.components.sensor.miflora] Not yet enough data for median calculation
At the end the problem was on the device. I took out battery and put again. Then i configured bluetooth on raspberry pi (pari, trust and connect) and then i begin to have values in HA.
I have a similar issue and cannot find a solution for it…
I am trying to set up my Mi Floor Plant Sensors (working with Bluetooth LE). I tried like its described within the manual (https://www.home-assistant.io/integrations/mitemp_bt/). According to this BLE should be enabled by default on the hass.io image. But I do not have hcitool or bluetoothctl available from command line in hass.io raspberry pi. Does anyone knows what I have to do to enable them?
Although the bluetooth tools mentioned where not available I was able to get the MAC address using BLE Scanner on Android. But if i put in the corresponding MAC to configuration.yml I do not get any updates/values from the sensor although it is within 2-3m from the raspberry pi. Is there anything else that I need to configure on either hass.io/raspberry pi/homeassistant?
