Because of Hardware/Software Limitations I am currently using 3 different devices:
A Raspberry PI to run the Python Script natively and connect to the Bluetti devices via Bluetooth.
Then I have a newly Test-Setup of HA on an Intel NUC. There I started the add-on “MQTT Broker”.
Then from the past with all my data on it a HA in a docker on a Synology NAS which connects to the MQTT Brocker to receive the different values for AC, DC, Akku percentage.
Since HA supports Bluetooth natively it should be possible to integrate that python script directly into HA without the need for an MQTT Brocker/Client in between. Unfortuantely my programming knowledge is to limited but maybe somebody with more knowledge would give it a try.
Is this your own thing or is it downloadable? Ps, I’m an hour into my first HA setup, and got my AC220MAX working, but want this pretty view, and history graphs later.
Do you see any values on sensor.ac200m_power_generation? My AC200Max just reports 0:
Total Power Generation (sensor.ac200m_power_generation)
MQTT discovery data:
Topic: homeassistant/sensor/2246000032299_power_generation/config
Payload
Subscribed topics:
bluetti/state/AC200M-2246000032299/power_generation
10 most recently received message(s)
Received 11:44:54 AM
QoS: 0
Payload: 0
Received 11:45:24 AM
QoS: 0
Payload: 0
Received 11:45:54 AM
QoS: 0
Payload: 0
Received 11:46:24 AM
QoS: 0
Payload: 0
Received 11:46:54 AM
QoS: 0
Payload: 0
Received 11:47:24 AM
QoS: 0
Payload: 0
Received 11:47:54 AM
QoS: 0
Payload: 0
Received 11:48:24 AM
QoS: 0
Payload: 0
Received 11:48:54 AM
QoS: 0
Payload: 0
Received 11:49:24 AM
QoS: 0
Payload: 0
I feel a little dumb but where do you get the MAC address that is needed to configure the integration Bluetti2MQTT ?
I was looking for it in the Bluetti app or in the settings screen directly on the battery and I couldn’t see it.
It should work with all sensors the bluetti_mqtt software uses and works with the HA Bluetooth proxies. If you find a bug, please let me know so I can improve the integration.
I am a new user of AC300 with dual solar array. I was wondering how can I add DC2 input Voltage to MQTT range of sensors? Is it Available? Or only for AC300?
Yes i try to use this setup.
Many stones must be roll.
I have now got it up and running. Unfortunately not as expected and desired.
The AC input power supply switches to, only when the electricity price is low and ends when the electricity price is above the daily AVG.
Devices that use the current from the battery are then connected to the AC. When the battery is empty, I switch it on again automatically for charging. Each plug can be controlled with a smart plug :-/
