Today I migrated from a SONOFF ZBDongle-P to Skyconnect for my Zigbee network in Home Assistant - using ZHA.
Migration worked great. I then flashed the Sonoff to use as a router. Issue I found with using as a router, is that during the migration the skyconnect took the same IEEE address as the sonoff. So now when I try to add the Sonoff, it doesn’t work because it has the same IEEE as the skyconnect coordinator.
Any advice on this? Is there a way to change the IEEE on either the Skyconnect or my Sonoff so that I can still use the Sonoff as a router?
Thanks @jerrm - I am trying your suggestion because it appears flash programmer 2 doesn’t work with the latest router firmware, known issue…
@jerrm — how do I set the secondary address? I used the below command to flash it, but it did not change the IEEE or set a secondary access that I can see. Is there a way I can update the command to do this?
After flashing I still have the same problem where ZHA sees the same IEEE as skyconnect when I try to add Sonoff as a router., Hoping you can point out a way I can update the above command so that I can fix this.
