I have HA OS (latest) on a Windows server under Hyper-V. And now I want to move this HA instance to Raspberry PI 4. OS version of course.
Is it possible?
I tried to make a backup (instance on Hyper-V) and then a restore (instance of RPI), but the restore on RPI every time causes non-functionality of HA. The CLI works but the web UI does not. It says the error “ERR_CONNECTION_REFUSED”.
Does it make sense to look at the logs and find out what the problem is? There are many various errors in logs.
Over backup section in UI ( Settings > System > Backups ).
After that I downloaded it and upload on onboarding.
Also I tried setup clearly new instance, setup and after that over UI upload and restore backup.
Same result
No, the VM is still running. And this instance is still available.
Hmm, after restoring from a VM backup, is its old IP address (the IP assigned to the VM) set to RPI? Because the CLI shows a different IP than the VM IP.
I did not think that it would also take over the IP settings.
As soon as I have the opportunity to temporarily shut down the old instance, I will try it.
Now before you go: please mark the post that helped you as the solution so anyone who’s searching for this can benefit from it.
You do that by selecting the three dots under the post:
Then select the check box:
Also, by doing so this prevents that someone else steps in for trying to help.
Summarized solution:
As @NathanCu wrote, restoring backups also restores all network settings. If the old IP is listed somewhere in the configuration, it needs to be changed or the old IP provided to the new server.
In my case, the port was changed, which also changed to the new server after restoring the backup. The UI with the new port is already working.
