I am running Home Assistant Core on a Raspberry Pi 3 with Debian 11. I installed the system with command line according to
With the missing app store, I see an increasing need to move on to Home Assistant Supervised which is offering more capabilities and convenience. I know I could just format the sdcard and start from scratch. Most likely using this thread:
https://community.home-assistant.io/t/installing-home-assistant-supervised-on-debian-11/
But then I would need to start from scratch.
The setup so far is quite simple as there are no rules (yet). The twenty one-wire DS18B20 sensors are monitored and are working fine. As well as some wifi switches.
I am wondering if there is an intelligent way to upgrade an existing (working) system from Core to Supervised.
