i have InfluxDB v1 running on my Home Assistant System. The Database ist about 10GB large. Every Backup takes me to long time so i hope someone could help me with an Toutorial to Migrate the Internal InfluxDB v1 to an dedicated server InfluxDBv1 or v2. So i could backup the Database-Server.
if someone can support me I would be very happy about it
This is not quite straightforward but I’ve done this, I think the upgrade to v2 didn’t go well so I kept the same version of influxdb
Here are my notes
# /disks/usb1/backups/homeassistant/migration/influx/data/influxdb:/var/lib/influxdb/data
# not so straightforward
# note homeassistant addon comes with kapacitor and Chronograf for easy administration
# influx 1.x
# rsynced old db
# noticed http calls
# CLEAR SUBSCRIPTIONS
# docker exec
# influx
# show subscriptions
# drop subscription "kapacitor-cf39975a-287c-4a16-a44e-b90fe7711603" ON "_internal"."monitor"
# drop subscription "kapacitor-cf39975a-287c-4a16-a44e-b90fe7711603" on "ha"."autogen"
# check new ha is posting data in
# SELECT * FROM "°C" WHERE time > now() - 1h;
# SELECT * FROM "W" WHERE time > now() - 1m;
docker run -d --name="influxdb" \
--restart=unless-stopped \
-p 10.0.0.3:8086:8086 \
-v /_dev/docker/influxdb/influxdb:/var/lib/influxdb \
docker.io/library/influxdb:1.8.4
Note that the ha password is retained from the old addon
influxdb:
host: replace_with_your_ip
port: 8086
database: ha
username: homeassistant
password: !secret influx_pwd
max_retries: 3
default_measurement: state
Did the same for Grafana addon, note the admin password is also retained by the old db files
