After installing 2024.6 I have a repair message that says:
I guess this relates to an automation which includes:
- service: notify.energy
data_template:
message: >-
{{ now().day}}/{{now().month}}/{{now().year}},{{
now().hour}}:{{now().minute}}:{{now().second}},{{
states.sensor.givtcp_ed2248g390_pv_energy_total_kwh.state }},{{
states.sensor.givtcp_ed2248g390_import_energy_total_kwh.state }},{{
states.sensor.givtcp_ed2248g390_export_energy_total_kwh.state}}
when I edit this automation I can see that the notify.energy service has a new format e.g.
metadata: {}
data: {}
but I can’t figure where to put my data template to make it work. Any ideas? TIA
this is just the notify format, not specifically notify.energy… and i think your notify.energy is actually using the file notify?
so if i’m understanding it right, perhaps just this?
message: >-
so “data_template” becomes “data” ?
Now I have this message:
My whole automation looks like this:
alias: 13. Energy hourly values
description: ""
- platform: time_pattern
minutes: "59"
condition: []
message: >-
mode: single
which sat with an entry in configuration.yaml
# file notify #
#notify:
# - name: energy
# platform: file
# filename: /config/files/energy.csv
# timestamp: false
Do I need to be looking for a new way to copy hourly values to a file?
this work for you?
description: ""
minutes: "59"
condition: []
- service: notify.send_message
entity_id: notify.energy
message: >-
mode: single
warning freehand coded this…
The error message is gone.
I’ll check the CSV fle later.
Thank you.
lucode
(Lucas)
6
I use Node-Red but if I switch to the “notify.send_message” service I get an API error.
Service needs to be the phone in my case.
I don’t have an automation that uses the print_export file.
Any ideas why the error is still present.
