Migrate Sonoff usb Zigbee Dongle-P to Dongle-E
I am currently using a Dongle-P and will soon be migrating to the new version, Dongle-E.
Do you have any advice for me?
Thank you for your advice!
were you able to migrate to the new dongle without rebuilding your whole network?
I have the same task … the new dongle sits already on my desk waiting… I am just unsure, if I need to re-pair everything after replacing the dongle… or if I can somehow use a backup of the network / use “migrate radio”…
Hi all, any progress on this? I have the same case: need to replace from Dongle-P to Dongle-E. Simply changing the serial port to point to a new USB dongle in zigbee2mqtt configuration did not work. I would like to avoid redoing all the config, re-pairing entities and devices and reconfiguring dashboards… Any hints would be appreciated.
the only way was to repair everything… :frowning:
Thanks for the feedback and sorry to hear there is not an easy way… I feel like there must be an option, so hope that someone can still come with a solution!
