@FlameBoy Did you ever manage to complete the migration?
I followed the guides, but encountered a bunch of type errors:
2023-10-19T13:54:34.245002Z WARNING Source column "public"."statistics_meta"."id" is casted to type "bigint" which is not the same as "integer", the type of current target database column "public"."statistics_meta"."id".
2023-10-19T13:54:34.245002Z WARNING Source column "public"."statistics_meta"."statistic_id" is casted to type "text" which is not the same as "character varying", the type of current target database column "public"."statistics_meta"."statistic_id".
2023-10-19T13:54:34.245002Z WARNING Source column "public"."statistics_meta"."source" is casted to type "text" which is not the same as "character varying", the type of current target database column "public"."statistics_meta"."source".
2023-10-19T13:54:34.245002Z WARNING Source column "public"."statistics_meta"."unit_of_measurement" is casted to type "text" which is not the same as "character varying", the type of current target database column "public"."statistics_meta"."unit_of_measurement".
2023-10-19T13:54:34.245002Z WARNING Source column "public"."statistics_meta"."name" is casted to type "text" which is not the same as "character varying", the type of current target database column "public"."statistics_meta"."name".
2023-10-19T13:54:34.245002Z WARNING Source column "public"."recorder_runs"."run_id" is casted to type "bigint" which is not the same as "integer", the type of current target database column "public"."recorder_runs"."run_id".
2023-10-19T13:54:34.245002Z WARNING Source column "public"."schema_changes"."change_id" is casted to type "bigint" which is not the same as "integer", the type of current target database column "public"."schema_changes"."change_id".
2023-10-19T13:54:34.246002Z WARNING Source column "public"."schema_changes"."schema_version" is casted to type "bigint" which is not the same as "integer", the type of current target database column "public"."schema_changes"."schema_version".
2023-10-19T13:54:34.246002Z WARNING Source column "public"."statistics"."id" is casted to type "bigint" which is not the same as "integer", the type of current target database column "public"."statistics"."id".
2023-10-19T13:54:34.246002Z WARNING Source column "public"."statistics"."metadata_id" is casted to type "bigint" which is not the same as "integer", the type of current target database column "public"."statistics"."metadata_id".
2023-10-19T13:54:34.246002Z WARNING Source column "public"."statistics_runs"."run_id" is casted to type "bigint" which is not the same as "integer", the type of current target database column "public"."statistics_runs"."run_id".
2023-10-19T13:54:34.246002Z WARNING Source column "public"."statistics_short_term"."id" is casted to type "bigint" which is not the same as "integer", the type of current target database column "public"."statistics_short_term"."id".
2023-10-19T13:54:34.246002Z WARNING Source column "public"."statistics_short_term"."metadata_id" is casted to type "bigint" which is not the same as "integer", the type of current target database column "public"."statistics_short_term"."metadata_id".
2023-10-19T13:54:34.246002Z WARNING Source column "public"."state_attributes"."attributes_id" is casted to type "bigint" which is not the same as "integer", the type of current target database column "public"."state_attributes"."attributes_id".
2023-10-19T13:54:34.246002Z WARNING Source column "public"."event_data"."data_id" is casted to type "bigint" which is not the same as "integer", the type of current target database column "public"."event_data"."data_id".
2023-10-19T13:54:34.246002Z WARNING Source column "public"."event_types"."event_type_id" is casted to type "bigint" which is not the same as "integer", the type of current target database column "public"."event_types"."event_type_id".
2023-10-19T13:54:34.246002Z WARNING Source column "public"."event_types"."event_type" is casted to type "text" which is not the same as "character varying", the type of current target database column "public"."event_types"."event_type".
2023-10-19T13:54:34.246002Z WARNING Source column "public"."states_meta"."metadata_id" is casted to type "bigint" which is not the same as "integer", the type of current target database column "public"."states_meta"."metadata_id".
2023-10-19T13:54:34.246002Z WARNING Source column "public"."states_meta"."entity_id" is casted to type "text" which is not the same as "character varying", the type of current target database column "public"."states_meta"."entity_id".
2023-10-19T13:54:34.246002Z WARNING Source column "public"."events"."event_id" is casted to type "bigint" which is not the same as "integer", the type of current target database column "public"."events"."event_id".
2023-10-19T13:54:34.246002Z WARNING Source column "public"."events"."event_type" is casted to type "text" which is not the same as "character", the type of current target database column "public"."events"."event_type".
2023-10-19T13:54:34.246002Z WARNING Source column "public"."events"."event_data" is casted to type "text" which is not the same as "character", the type of current target database column "public"."events"."event_data".
2023-10-19T13:54:34.246002Z WARNING Source column "public"."events"."origin" is casted to type "text" which is not the same as "character", the type of current target database column "public"."events"."origin".
2023-10-19T13:54:34.247002Z WARNING Source column "public"."events"."context_id" is casted to type "text" which is not the same as "character", the type of current target database column "public"."events"."context_id".
2023-10-19T13:54:34.247002Z WARNING Source column "public"."events"."context_user_id" is casted to type "text" which is not the same as "character", the type of current target database column "public"."events"."context_user_id".
2023-10-19T13:54:34.247002Z WARNING Source column "public"."events"."context_parent_id" is casted to type "text" which is not the same as "character", the type of current target database column "public"."events"."context_parent_id".
2023-10-19T13:54:34.247002Z WARNING Source column "public"."events"."data_id" is casted to type "bigint" which is not the same as "integer", the type of current target database column "public"."events"."data_id".
2023-10-19T13:54:34.247002Z WARNING Source column "public"."events"."origin_idx" is casted to type "bigint" which is not the same as "smallint", the type of current target database column "public"."events"."origin_idx".
2023-10-19T13:54:34.247002Z WARNING Source column "public"."events"."event_type_id" is casted to type "bigint" which is not the same as "integer", the type of current target database column "public"."events"."event_type_id".
2023-10-19T13:54:34.247002Z WARNING Source column "public"."states"."state_id" is casted to type "bigint" which is not the same as "integer", the type of current target database column "public"."states"."state_id".
2023-10-19T13:54:34.247002Z WARNING Source column "public"."states"."entity_id" is casted to type "text" which is not the same as "character", the type of current target database column "public"."states"."entity_id".
2023-10-19T13:54:34.247002Z WARNING Source column "public"."states"."state" is casted to type "text" which is not the same as "character varying", the type of current target database column "public"."states"."state".
2023-10-19T13:54:34.247002Z WARNING Source column "public"."states"."attributes" is casted to type "text" which is not the same as "character", the type of current target database column "public"."states"."attributes".
2023-10-19T13:54:34.247002Z WARNING Source column "public"."states"."event_id" is casted to type "bigint" which is not the same as "smallint", the type of current target database column "public"."states"."event_id".
2023-10-19T13:54:34.247002Z WARNING Source column "public"."states"."old_state_id" is casted to type "bigint" which is not the same as "integer", the type of current target database column "public"."states"."old_state_id".
2023-10-19T13:54:34.247002Z WARNING Source column "public"."states"."attributes_id" is casted to type "bigint" which is not the same as "integer", the type of current target database column "public"."states"."attributes_id".
2023-10-19T13:54:34.247002Z WARNING Source column "public"."states"."origin_idx" is casted to type "bigint" which is not the same as "smallint", the type of current target database column "public"."states"."origin_idx".
2023-10-19T13:54:34.247002Z WARNING Source column "public"."states"."context_id" is casted to type "text" which is not the same as "character", the type of current target database column "public"."states"."context_id".
2023-10-19T13:54:34.248002Z WARNING Source column "public"."states"."context_user_id" is casted to type "text" which is not the same as "character", the type of current target database column "public"."states"."context_user_id".
2023-10-19T13:54:34.248002Z WARNING Source column "public"."states"."context_parent_id" is casted to type "text" which is not the same as "character", the type of current target database column "public"."states"."context_parent_id".
2023-10-19T13:54:34.248002Z WARNING Source column "public"."states"."metadata_id" is casted to type "bigint" which is not the same as "integer", the type of current target database column "public"."states"."metadata_id".
I allowed HA to create the scheme in Postgres so that should be correct, and I used the same pgloader script everyone else seems to have working, so not sure what’s going wrong in my case. I dropped the fields that aren’t in the new schema, but I doubt that’s the cause of these issues.
I’m stumped…
