I try to migrate my wifi zigate from custom_components to ZHA.
I removed old configuration and set this one :
zha:
usb_path: socket://192.168.1.210:9999
radio_type: zigate
database_path: /home/homeassistant/.homeassistant/zigbee.db
It does not seem working, I get errors on hass starting :
> Mar 26 14:05:10 raspi hass[29712]: 2020-03-26 14:05:10 ERROR (MainThread) [homeassistant.components.zha.core.gateway] Couldn't start EZSP coordinator
> Mar 26 14:05:10 raspi hass[29712]: Traceback (most recent call last):
> Mar 26 14:05:10 raspi hass[29712]: File "/home/homeassistant/homeassistant/lib/python3.7/site-packages/homeassistant/components/zha/core/gateway.py", line 142, in async_initialize
> Mar 26 14:05:10 raspi hass[29712]: res = await self.application_controller.startup(auto_form=True)
> Mar 26 14:05:10 raspi hass[29712]: File "/home/homeassistant/homeassistant/lib/python3.7/site-packages/bellows/zigbee/application.py", line 135, in startup
> Mar 26 14:05:10 raspi hass[29712]: await self.initialize()
> Mar 26 14:05:10 raspi hass[29712]: File "/home/homeassistant/homeassistant/lib/python3.7/site-packages/bellows/zigbee/application.py", line 72, in initialize
> Mar 26 14:05:10 raspi hass[29712]: await e.reset()
> Mar 26 14:05:10 raspi hass[29712]: File "/home/homeassistant/homeassistant/lib/python3.7/site-packages/bellows/ezsp.py", line 57, in reset
> Mar 26 14:05:10 raspi hass[29712]: await self._gw.reset()
> Mar 26 14:05:10 raspi hass[29712]: File "/home/homeassistant/homeassistant/lib/python3.7/site-packages/bellows/uart.py", line 222, in reset
> Mar 26 14:05:10 raspi hass[29712]: return await asyncio.wait_for(self._reset_future, timeout=RESET_TIMEOUT)
> Mar 26 14:05:10 raspi hass[29712]: File "/usr/lib/python3.7/asyncio/tasks.py", line 423, in wait_for
> Mar 26 14:05:10 raspi hass[29712]: raise futures.TimeoutError()
> Mar 26 14:05:10 raspi hass[29712]: concurrent.futures._base.TimeoutError
and after I get more errors :
Mar 26 14:05:16 raspi hass[29712]: 2020-03-26 14:05:16 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry socket://192.168.1.210:9999 for binary_sensor
Mar 26 14:05:16 raspi hass[29712]: Traceback (most recent call last):
Mar 26 14:05:16 raspi hass[29712]: File "/home/homeassistant/homeassistant/lib/python3.7/site-packages/homeassistant/config_entries.py", line 216, in async_setup
Mar 26 14:05:16 raspi hass[29712]: hass, self
Mar 26 14:05:16 raspi hass[29712]: File "/home/homeassistant/homeassistant/lib/python3.7/site-packages/homeassistant/components/binary_sensor/__init__.py", line 133, in async_setup_entry
Mar 26 14:05:16 raspi hass[29712]: return await hass.data[DOMAIN].async_setup_entry(entry)
Mar 26 14:05:16 raspi hass[29712]: File "/home/homeassistant/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity_component.py", line 156, in async_setup_entry
Mar 26 14:05:16 raspi hass[29712]: raise ValueError("Config entry has already been setup!")
Mar 26 14:05:16 raspi hass[29712]: ValueError: Config entry has already been setup!
Mar 26 14:05:16 raspi hass[29712]: 2020-03-26 14:05:16 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry socket://192.168.1.210:9999 for cover
Mar 26 14:05:16 raspi hass[29712]: File "/home/homeassistant/homeassistant/lib/python3.7/site-packages/homeassistant/components/cover/__init__.py", line 145, in async_setup_entry
Mar 26 14:05:16 raspi hass[29712]: 2020-03-26 14:05:16 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry socket://192.168.1.210:9999 for device_tracker
Mar 26 14:05:16 raspi hass[29712]: File "/home/homeassistant/homeassistant/lib/python3.7/site-packages/homeassistant/components/device_tracker/config_entry.py", line 26, in async_setup_entry
Mar 26 14:05:16 raspi hass[29712]: return await component.async_setup_entry(entry)
Mar 26 14:05:16 raspi hass[29712]: 2020-03-26 14:05:16 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry socket://192.168.1.210:9999 for fan
Mar 26 14:05:16 raspi hass[29712]: File "/home/homeassistant/homeassistant/lib/python3.7/site-packages/homeassistant/components/fan/__init__.py", line 99, in async_setup_entry
Mar 26 14:05:16 raspi hass[29712]: 2020-03-26 14:05:16 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry socket://192.168.1.210:9999 for light
Mar 26 14:05:16 raspi hass[29712]: File "/home/homeassistant/homeassistant/lib/python3.7/site-packages/homeassistant/components/light/__init__.py", line 271, in async_setup_entry
Mar 26 14:05:16 raspi hass[29712]: 2020-03-26 14:05:16 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry socket://192.168.1.210:9999 for lock
Mar 26 14:05:16 raspi hass[29712]: File "/home/homeassistant/homeassistant/lib/python3.7/site-packages/homeassistant/components/lock/__init__.py", line 77, in async_setup_entry
Thanks for help!
