Migrated to Debian from Home Assistant OS RPI
I migrated from an Raspberry Pi (Home Assistant OS) to a linux Debian install on amd64.
Everything works as expected, but I’m not able to validate my configuration or restart the in server manager.
I can only do this through “ha core restart” or “check” in a terminal shell.
And when I run the “ha core check” I get message about Raspberry PI" :frowning:
Error: Testing configuration at /config
INFO:homeassistant.util.package:Attempting install of RPi.GPIO==0.7.0
Fatal error while loading config: This module can only be run on a Raspberry Pi!
Failed config
  General Errors:
    - This module can only be run on a Raspberry Pi!
Successful config (partial)
I found my problem :slight_smile: I was able to identify an old integration that I was running on my RPI, once I removed it, my check came back clean. And I can now restart from the client :slight_smile:
